Question about Briggs & Stratton Briggs and Stratton Pressure Washer 6.5 $200
How do In remove carbie from 13hp briggs and stratton
Removed carbie top and it appears I need to remove plastic air shroud?
  • 41 Answers
Correct! work your way down to the carburetor, careful not to tear any seals or hoses. once you get the shroud off, mark the throttle and governor linkage and be careful not to bend them. From there on out it should be 2-4 bolts or screws holding it on to the manifold. replacement is reverse of tear down. Model and serial numbers would help me to help you further, if any is needed! Good Luck to ya!
Posted on Jan 08, 2015
3 Suggested Answers
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
Posted on Apr 23, 2010
How do i remove float chamber on a 13hp briggs & stratton
that solenoid unscrews and then the bowl pops loose . Unplug it first tho . believe it takes 1/2 inch thin wrench like a tappet wrench
Jul 23, 2015 | Garden
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
My Briggs & Stratton 500 Series with model 10T502, Type 0495 B1, and Code 07011 855 failed to start after I cleaned it because the rope/string had no tension on it. What do I need to do to get it...
Does the starter rope rewind? If So and You removed the engine shroud you have to be sure the Pull Starter lines up with the flywheel nut. If the rope does not rewind the return spring is broken so you have to get a spring and remove the shroud and install it. I would take the shroud off and with me to get the spring and the place may install it for you. Bolt the shroud back on and you should be in business.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Gas got into the oil through carb. changed oil. rope won't pull. 13hp briggs on a generator.
STOP...The engine crankcase is FULL of gas and oil..NOT A GOOD THING...
remove the spark plug,,,drain the oil.. let the engine "air" out,,, have the carb cleaned and set..
Jan 28, 2010 | Briggs Stratton 020273 Elite Series...
How to replace starter ring on husqvarna yt130 with B & S 13hp engine. I have removed the flywheel. Nylon starter ring appears to be riveted on. Can I buy the ring only or do I buy the flywheel...
Briggs offers a kit to replace the plastic ring gear with an aluminum ring gear. Remove the gear by drilling the rivets and punching them out. The kit comes with bolts, ring gear, and starter gear, plus instructions. Go to your local briggs dealer with the model, type, code numbers of the engine. Aprox $40 cost. If you cannot find a dealer, I can offer the part to you. thanks, mowerguy
Nov 08, 2009 | Husqvarna Garden
RPM fluxuates/pulsates
It sounds like a piece of dirt is in carburetor.You could try the quick clean first,remove the flywheel screen and the plastic engine shroud.The top of the carburetor will be exposed now.Remove the 3 small screws from the plat on top of the carb.Use air or carburetor cleaned and blow out these passages. Be sure to cover with a rag when doing this to shield your face from spray back.Test run and see if that helps,if not you will have to remove the carburetor and disassemble it to clean it.
Jul 30, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs and Stratton Pressure Washer 6.5 $200 Logo
82 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
