Question about Garmin GPS 12 GPS Receiver
Hello I have a Garmin Gps 12 with Dead Pixel lines running across the display when I start the unit and it stays on while i am using it.Is there a way to fix this problem? and also on my other 12 uni
I tried using the DC power kabel as someone suggested but did not work.Left the display in simulator mode mode for a while with new batteries for 2 days but did not work.Is there a possibility to buy the display units for the Garmin Gps 12? Regards De Silva
  • Garmin Master
  • 2,130 Answers
Any dead pixels on the screen are an indication of a defective LCD display. The display must be replaced.
Posted on Dec 15, 2014
4 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Posted on Mar 05, 2009
  • 59 Answers
SOURCE: garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Posted on Apr 25, 2009
  • 3287 Answers
SOURCE: the unit won't charge...it says "low battery". i
Sandra,
I don't know where you live - so I don't know who nearby can work on it. Regardless, my suggestion is to return it to Garmin and let them handle it. Since your nuvi 760 is out of warranty, Garmin will charge $99 to "factory overhaul" it. What this means really is, you will get a factory rebuilt nuvi 760. Garmin will not fix yours and return it to you - but rather they will send one that that belonged to someone else that they refurbished. This means really fast "turn around" instead of waiting for yours to be fixed. In short, you will not get the same one you sent in. The refurbished unit will come with the latest up - to - date maps and have a 90 day factory warranty.
Check out Garmin's page to learn more about this overhaul service and to take advantage of it. If you do send it in - your data will be lost. Garmin will erase all your personal data, photos, etc. from the nuvi (and they won't put it on the replacement) - so if there's anything on it that you want - be sure to copy it before sending in.
I hope this helps & good luck! Please rate my reply - thank you.
Posted on Feb 18, 2011
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
Hello, I own Garmin edge 705 I cannot turn it on when plugged to charger display shows battery icon close to empty (2 pixel line) and no charging is happening at all when connected to computer via...
Sounds like your battery has gone bad to me. I also own a garmin. I would suggest you contact garmin for repairs. You can go to their web site at www.garmin.com go to the top of the page where it says My garmin and log in to your account. If you don't have one then sign up for one its free. Then contact technical support either by email or by phone to get your unit repaired.
I hope this helps you out if it does please give me a YES on the web page you just received my response on. Thank you
Apr 13, 2011 | Garmin Edge 705 Handheld GPS Receiver
GARMIN 305 WONT PICKUP ANY STATELLITE
Try giving your unit a firmware update using Garmins WebUpdater software, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp. If this dosent work your units GPS receiver is probably dead and should be sent in for repair.
Hope this helps!
Feb 18, 2011 | Garmin Forerunner 305 GPS Receiver
My 3 year old Garmin Etrex Vista just started displaying horizontal lines across the entire display. Any suggestions?
Try updating the unit's software via the Garmin.com website. This may fix it as there was a satellite launched which was causing problems with some Garmin units.
Sep 25, 2009 | Garmin eTrex Vista GPS Receiver
Unit powers up then abruptly shuts down
Battery is almost dead. I had the same problem. Had to keep charging battery for about 12 hours thru my PC. That solved my problem.
Anil
May 12, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin gps 12 wont turn on.
Apr 20, 2009 | Garmin GPS 12XL GPS Receiver
Garmin GPS 152
I had the same problem so I replaced my 152 with a spare unit. It did the same thing. This led to believe it was the cable. I removed a few kinks and a bend at the unit; and it seems to be fine. Seems too simple and the bends were not that severe, but it is working (for now).
Aug 24, 2008 | Garmin GPS 152 GPS Receiver
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin GPS 12 GPS Receiver Logo
165 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
