Question about Toro Garden
My toro z4202 will not start it is not the battery as it is ok
I hav checked the battery and is fully chrged
  • Toro Master
  • 1,169 Answers
First must sure you have both control arms are in neutral and the PTO switch is off. Depending on your model setup test for voltage at solenoid control terminal. If the voltage is present and your setup uses the separate solenoid check for voltage at each of the two large terminals while trying to crank there should be voltage on both of these if not then the internal contacts are burned and solenoid need replacing.
If no voltage at the solenoid control terminal then you need check the switches at the control arms, the PTO switch and the ignition switch.
The operator and service manual are available at the following link which contains the wiring diagrams.
Toro Z4202 (74381)
Posted on Dec 15, 2014
Battery or motor?
check the battery and the charger with a multimeter and make sure they are showing the correct volts, and then check the voltage wires where they connect to the motor and see if its showing the correct volts there when the foot pedal is pressed
Jan 17, 2014 | Peg Perego IGED1084 Santa Fe Train
My 1979 ford f 350 will not start. When the key is turned I can here a single click, The battery is fully chrged and a new starter has been installed. Afterwards I still got a single click when the key was...
It's the solenoid....Follow the positive cable from the battery too...it is connected to the solenoid.
there will be 3 maybe 4 wires...two bolted one or two push on....change this and you should be good to go...
Jul 06, 2011 | 1979 Ford F 350
7 days ago i took my battery off to charge my camera and its fully chrged i put it back onto the camera and it just wont start up. I bought another battery and fully charged it aso and it wont turn on!...
Please make sure that the battery is clean and also the terminals within are clean. If you had been using the camera prior to the charging then the camera must work unless if the battery was spoiled by wrong charging. If you can use a multimeter to check the voltage which must be as specified on the battery label. Now make sure that the battery gets good contacts into the camera when inserted. If this wont work then it possible that there are errors within the camera and you need help from the nearest Nikon center.click the link below
http://www.nikonusa.com/Service-And-Support/Product-Support.page
Mar 28, 2011 | Nikon D3000 Digital Camera
Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Oct 23, 2009 | Toro Lawn Mower With Toro Power Tools
Motor will not turn over tries but stop battery fully charged
Took spark plug out spun motor found out was loaded fith fuel, put plug back in then it started O.K.
Aug 15, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Motorola slvr unable to power on
wait until the phones battry get fully chrged working with a fully drained battery is bad to phone as wellas battery itself
Dec 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Garden Logo
83 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
