Estudio 161 leaking toner. the cartridge is new. How do I stop the leak?
    Sergeant:
  • Office Equip... Expert
  • 224 Answers
Developer unit bush and seal check if need replaced them
Posted on Dec 15, 2014
Toner not recongnised estudio-18
change the older cartridge chip to new one
Feb 06, 2014 | Toshiba Office Equipment & Supplies
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
Dell 3000cn leaking black toner cartridge
If they all have leaking, I would bet its the fuser causing the issue. It sounds like its not sealing the ink properly, thus it looks like its leaking.
Apr 07, 2010 | Dell 3000cn Laser Printer
Toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Mar 27, 2010 | Sharp AL 1631 Copier
It leaks. It's all over the inside of machine. We don't use this printer a lot because we do design on-line; so it's not from overuse or worn out parts. It just leaks and then causes the printer to stop...
I have had problems with a number of brand new genuine HP toner cartridges leaking on this printer. Strangely, I have had almost no problems with non-OEM cartridges from Cartridge World.
I can’t explain this...and wouldn’t have believed this if I hadn’t experienced it myself.
Try removing all toner cartridges, and carefully cleaning out the printer with canned air. Then replace the leaky toner cartridges with Cartridge World cartridges. This has been my recipe for success with the HP Laserjet 4600.
Nov 16, 2009 | HP LaserJet 4600 Printer
Toner Leaking
are the new ones original toners ? if not, then you have to buy a new original or working toners, because, its not recomended to refill toners, but if you want, then you can refill them only about 1-2 times.
Jan 31, 2008 | Konica Minolta magicolor 2400 Laser...
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
24 people viewed this question
k24674
jasbo
jasbo
