Question about Irons
Hi there The little clasp/catch that covers the water well has snapped off - can this be repaired or would I need to buy a new iron? It's a Tefal Avantis 120 Many thanks Tracy
    Master:
  • Irons Master
  • 996 Answers
Leakage,wrisky to use, buy a newone
Posted on Jan 21, 2015
3 Suggested Answers
SOURCE: I have a Tefal Pro express iron and I have water
There is a seal or a connection leaking. Take the iron apart -- you'll probably see where it's been leaking.
Posted on May 04, 2009
emissionwiz
  • 76691 Answers
SOURCE: dont know how to descale tefal turbo potect iron
descaling is down with white vinguar.
Posted on Jul 21, 2009
The steam is building up in the water tank but not going through to the iron.
I suspect that the discharge holes have become clogged by calcified deposites due to hard water. You need to de-calcify the iron. Mix one cup of white vinegar with one cup of water and pour this mixture in the iron and let it heat up. The acidic vinegar should dissolve the build up. repeat until clear. forthe final, use a little lemon in a cup of water to get rid of the vinegar smell. You can prevent this by using only distilled water in the iron, but this is not really practical, so a couple of clearing runs of the vinegar/water bath each month will put this off.
Feb 09, 2011 | Tefal UltraGlide Easycord FV4256 Iron
Tefal 2932 pro express iron not steaming
Use different water in the iron...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 14, 2010 | Tefal Ultraglide 1549 Iron
Hello, my Tefal Virtuose iron only gets slightly warm even on the highest setting..does it need replacing or can it be fixed? Thanks!
Yes,it can be fixed. however, if the fixing cost a little lower than buying a new one, it is best to buy one.
Sep 21, 2009 | Irons
My Tefal Steam generator needs de-scaling i have the kit but I have lost the instructions
you can download new instructions from the web. Remove the anticalc cover at the side and unscrew the metal nut, take care to ensure the little rubber seal is still inside the nut and not stuck to the opening. Plug one end of the hose into the iron ( it will fit without moving as it can only go in one way) connect the other end to the tap, turn on the tap and watch it flush out all the build up. leave it flushing for a few minutes then turn off the water. personally I then empty all the water from the base and then put the nut and cover back on fill up the tank and iron.
Jun 05, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal program 8 500 Iron
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Hi, My Tefal Express Steam Iron is not working. The steam will not work and brown water is pouring out the bottom of the iron. I need to know where I should get this repaired in Inner West...
Do you use any additive to the water when you iron?
Do you empty the water out after use ?
Brown steam / water suggests foul water, or rust due to dirty water pipes on Iron.
With regards to 'not working' - do you have any lights on, or is it dead.
(I had one of these, the mains lead within the flex holder had broken - design flaw) - managed to repair.
Aug 11, 2008 | Tefal UltraGlide Easycord FV4256 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Irons Logo
51 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
