Question about Toshiba Televison & Video
THIS PROBLEM IS NOT LOGICAL-SIGNAL STRENGHTS HAVE BEEN CHECKED AND WAS OK BUT THE PICTUE KEEPS BREAKING DIFFERENT ON 3 DIFERENT TVS IN THE HOUSE BUT WHEN I REMOVE ANY ONE OF THEM AND CONNECR IT INTO O
ONE OLDER TOSHIBA WILL WORK ON ANY TV POINT IN THE HOUSE ANY OF THE OTHER 3 HAVE PROBLEMS WITH PICTURE BREAK UP EVEN WHEN USED ON THE SAME TV POINT BUT CAN BE OK . TV ARIEL HAS AN AMPLIFIER AND THEN GOES THROUGH A 6 WAY SPLITER BOX
    Top Expert:
  • Toshiba Master
  • 74,383 Answers
In fringe areas; where signal strength is too weak, this should happen. It sounds that, you're using an Ariel booster along with a splitter. Just connect one TV at a time, without using the splitter. If picture break occurs even this time, adjust the the signal strength of the booster [either low or high], and check whether it can help you. Keep in mind, iv the signal strength is too low, or set to too high, this fault will happen, as AGC [automatic Gain Control] circuit inside the set won't function properly. Gopakumar Gopalan Google
Posted on Dec 15, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 120 Answers
After testing a direct connection to one TV as first comment suggests make sure all your connections are still clean and secure. Each split and break in the line will decrease the signal. Try to use as few connections as possible. Make sure the cables you are using are shielded and rated for length you are running. Make sure the splitters are of descent quality.
Posted on Dec 27, 2014
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
T v signal keeps breaking up n losing channels
If cable etc have it looked at--line from it or a sat feed etc--could be a bad connection or a problem at the source if all sets have same issue--if I was for example using a single line coming in--disconnect it and hook it directly to a single set--if problem not there it is in the house--if there it is outside.
Jun 07, 2012 | Sony Televison & Video
Thread keeps breaking
check to see if there are any burrs in that area
May 24, 2012 | Husqvarna Sewing Machines
I've lost all programmes except BBC on my TV and retuning makes no difference. The other 3 TVs in the house are all functioning normally
I expect there is a tv aerial signal problem as depending on your area, bbc and itv use different frequencies and signal loss could be the problem.
Apr 15, 2011 | Televison & Video
Trying to install channels on goodmans ld1962d. Not sure what active antenna is. No channels are found when we have aerial in or out.
check for antena cable plug condition, normaly 80% of low quality of antena signal, is conection on antena plug (inside)
1st open antena plug, check for condition/connection of cable.
2nd check for each part of cable well connected, and no wires crossed on middle cable
3rd check same to the other end of cable.
4rd check the signal on diferent tvs around house (if available)
if this general you dont have aerial signal in your house, check for your TV provider (cable) to test your arial signal.(Normaly this maybe a cable broken outside house).
Nov 22, 2009 | Televison & Video
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
My facebook chat keeps being unavailable on my laptop but works ok on the computer in the other room it just keeps showing a yellow triangle
this happens when the networking device of your laptop is turned weak or about to go off.because of the weak signal receiving it keeps on breaking the connection and makes it unavailable. to solve the issue you need to get the signaling device of your laptop checked and if necessary get it replaced to avoid further inconvenience
thanks.
Aug 31, 2009 | Facebook Social Network
My analogue tv signal keeps dropping out for days at a time
do the isolation type, start by connecting one tv, if it works, connect another one and so on.
what is happening is that all the tvs are connected in parallel if one line shots then all lines goes off. because of common output.
okay
Apr 30, 2009 | Samsung Televison & Video
No signal on tv
i have 32ins Samsung displaying no satellite signal what is solution?
Aug 15, 2008 | LG Televison & Video
Televison & Video Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
