Question about Kyocera Office Equipment & Supplies
Kyocera Mita c610 error
C610 error
  • Kyocera Expert
  • 337 Answers
C0610 Bitmap (DIMM) problem
There is a problem with the data or
address bus of the bitmap DRAM.
Defective main
PWB.
Replace the main PWB and check for correct
operation.
DIMM installed
incorrectly.
Check if the DIMM is inserted into the socket
on the main PWB correctly.
Defective DIMM. Replace the DIMM and check for correct
operation.
Posted on Jan 08, 2015
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
n25an
  • 622 Answers
SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Posted on Dec 23, 2009
ganggawangsa
SOURCE: SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Posted on Nov 28, 2012
Possible solution for kyocera mita km-1530 c610 error?
This is temperature error code. For causes and solutions see this: C6100, How to reset
Feb 16, 2012 | Office Equipment & Supplies
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
Error AP kyocera mita km-1505?
AP means ADD POWDER, actually add toner.
Apr 18, 2010 | Kyocera KM-1505 Copier
Code erreur
c610Bitmap (DIMM) problem
Sep 08, 2009 | Kyocera KM-1510 Copier
Kyocera KM-1510 error c610
Broken fixing heater wire
Jul 10, 2009 | Kyocera KM-1510 Copier
SYSTEM ERROR
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Apr 03, 2008 | Office Equipment & Supplies
105 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
