Question about OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A
Diesel engine valve & rocker arm setting& governor setting
Generator starts fine,runs high then low...high then low...like lobing
check for a broken compensating spring on the governor to carby linkage
Mar 08, 2017 | Electrical Supplies
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
Why does my 8hp Honda keep braking rocker arms
stuck valves are the main cause of breakig rocker arms
Sep 22, 2014 | Honda 8 HP Engine
Governor reset
Are you asking how to reset governor linkage to factory spec? If so, move governor arm in direction that opens throttle valve on carb wide open. Hold in this position. Loosen small nut on bottom of governor arm. With a needle nose pliers turn center arm that goes into engine in the same direction you turned governor arm to open throttle valve. Holding in position, now tighten nut on governor arm tight again. This is referred to as a static setting and is factory spec. Good luck!
Sep 21, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Rocker arm torque specs on a 97 gmc jimmy 4.3
  1. For the 4.3L engines which are equipped with screw-in type rocker arm studs with positive stop shoulders, tighten the rocker arm adjusting nuts against the stop shoulders to 20 ft. lbs. (27 Nm) on 1994-96 models and 18 ft. lbs. (25 Nm) on 1997-99 models. No further adjustment is necessary, or possible.
  2. For most 4.3L engines which are not equipped with screw-in type rocker arm studs and positive stop shoulders, properly adjust the valve lash. For details on valve lash adjustment, please refer to the procedure in Routine Maintenance . (see below)
4.3L Engine
The 4.3L engines may be equipped with either of 2 rocker arm retaining systems. If your engine utilizes screw-in type rocker arm studs with positive stop shoulders, no valve lash adjustment is necessary or possible. If however, you engine utilizes the pressed-in rocker arm studs, use the following procedure to tighten the rocker arm nuts and properly center the pushrod on the hydraulic lifter:
  1. To prepare the engine for valve adjustment, rotate the crankshaft until the mark on the damper pulley aligns with the 0? mark on the timing plate and the No. 1 cylinder is on the compression stroke. You will know when the No. 1 piston is on it's compression stroke because both the intake and exhaust valves will remain closed as the crankshaft damper mark approaches the timing scale.
Another method to tell when the piston is coming up on the compression stroke is by removing the spark plug and placing your thumb over the hole, you will feel the air being forced out of the spark plug hole. Stop turning the crankshaft when the TDC timing mark on the crankshaft pulley is directly aligned with the timing mark pointer or the zero mark on the scale.
The valve arrangement is as follows:
E-I-I-E-I-E (right bank-front-to-rear) E-I-E-I-I-E (left bank-front-to-rear)
  1. With the engine on the compression stroke, adjust the exhaust valves of cylinders No. 1, 5 & 6 and the intake valves of cylinders No. 1, 2 & 3 by performing the following procedures:
    1. Back out the adjusting nut until lash can be felt at the pushrod.
    2. While rotating the pushrod, turn the adjusting nut inward until all of the lash is removed.
    3. When the play has disappeared, turn the adjusting nut inward 1 3 / 4 additional turns.
  2. Rotate the crankshaft one complete revolution and align the mark on the damper pulley with the 0? mark on the timing plate; the engine is now positioned on the No. 4 firing position. This time the No. 4 cylinder valves remain closed as the timing mark approaches the scale. Adjust the exhaust valves of cylinders No. 2, 3 & 4 and the intake valves of cylinders No. 4, 5 & 6, by performing the following procedures:
    3. When the play has disappeared, turn the adjusting nut inward 1 3 / 4 additional turn.
Sep 23, 2010 | 1997 GMC Jimmy
Need to know how to adjust the valves
On Vehicle Inspection If a clanging noise due to the lash adjuster produced immediately after the engine has started or during operation persists, perform the following checks:
  1. Check the engine oil, and add or replace if necessary.
    1. If the engine oil is low, the air drawn in from the oil strainer will be trapped in the oil passage.
    2. If the engine oil level is higher than the specified level, agitation of oil by the crankshaft could cause a large amount of air to enter the oil.
    3. A deteriorated oil contains a large amount of air, because the air, once trapped, is not readily separated from the oil. If the air trapped due to these causes enters the high pressure chamber in the lash adjuster, the air in the high pressure chamber will be compressed while the valve is in the opened position. The lash adjuster will be drawn too far in, and will produce noise when the valve closes. This is the same phenomenon that occurs when the valve clearance is adjusted to an excessive dimension. Fig. 1: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 2.0L, 2.3L, 2.4L and 2.6L Engines 86663205.gif
      Fig. 2: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.0L (12 Valve) Engines 86663206.gif
      Fig. 3: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.0L (24 Valve) Engines 86663236.gif
      Fig. 4: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.5L Engines 86663207.gif
      Fig. 5: Push the rocker arm to check if the rocker moves down or not — all engines except for the 3.5L Engines. 86663208.gif
      Fig. 6: Push the rocker arm to check if the rocker moves down or not — 3.5L Engines. 86663210.gif
      In this case, the normal condition will be restored if the air escapes from the lash adjuster.
  2. Start the engine and slowly race (accelerate the engine from idling speed to 3,000 rpm in 30 seconds and then decelerate it to the idling speed in 30 seconds) it several times (less than 10 times). If racing the engine causes the noise to die away, it means that the air has escaped from the high pressure chamber of the lash adjuster and that the lash adjuster has regained its normal functions.
    1. When the vehicle is parked on a slope for a long period of time, the oil in the lash adjuster will decrease. When the engine is started, the air might enter the high pressure chamber.
    2. After a long period of parking during which the oil in the oil passage goes away, it will take some time before the oil is re-supplied to the lash adjuster. Therefore, the air could enter the high pressure chamber.
  3. If any abnormal noise is not eliminated by racing, check the lash adjuster.
    1. Stop the engine.
    2. Set the engine so that cylinder No. 1 is positioned at the top dead center of the compression stroke.
    3. Press the rocker arm at the area indicated by the white arrow mark to check whether the rocker arm is lowered or not.
    4. Slowly turn the crankshaft 360°clockwise.
    5. In the same procedure as step "c'', check the rocker arm at the area indicated by the black arrow mark.
    6. Push down the rocker arm at a portion located right above the lash adjuster. If the rocker arm goes down readily, the lash adjuster is defective. Replace it with a new one in accordance with Step 4. In addition, when replacing the lash adjuster, be sure to remove air positively from the lash adjuster before installation. Then perform inspection in accordance with steps "a'' through "e'' to make sure that there is no abnormality. In addition, if the rocker arm is felt to be very stiff or cannot be pushed down when it is pushed, the lash adjuster is in the normal condition. Therefore, check for other causes of noise.
Bleeding and Checking When cleaning or checking the lash adjusters, use only clean diesel fuel. To test the lash adjusters, follow this procedure.
  1. Immerse the lash adjuster in clean diesel fuel.
  2. While lightly pushing down the inner steel ball using a small wire, move the plunger up and down four or five times to bleed air. The use of the retainer facilitates the air bleeding of the rocker arm mounted type lash adjuster.
  3. Remove the small wire and press the plunger in. If the plunger is hard to be pushed in, the lash adjuster is normal. If the plunger can be pushed in all the way readily, bleed the lash adjuster again and test again. If the plunger is still loose, replace the lash adjuster. NOTE: Upon completion of bleeding the air out of the lash adjuster, hold the adjuster upright to avoid the diesel fuel from spilling.
  4. After air bleeding, set the lash adjuster on the special tool (leak down tester MD998440).
  5. After the plunger has gone down somewhat 0.008–0.020 in. (0.2–0.5mm), measure the time needed for it to go down an additional 0.04 in. (1mm). Replace if the measured time is not between 4–20 seconds.
Sep 06, 2010 | 1991 Mitsubishi Mighty Max
I need the engine valve spec for a 1984 chevy 6.2 diesel. We are adjusting the valves.
VALVE ADJUSTMENTS All gasoline and diesel engines in this guide use hydraulic valve lifters, which require no periodic maintenance or adjustment. However, in the event of cylinder head removal or any operation that requires disturbing or removing the rocker arms, the rocker arms must be adjusted in order to position the pushrods to allow the hydraulic lifters to maintain zero lash. Refer to the valve lash adjustment procedure under Rocker Arms, earlier in this Section.
Aug 21, 2010 | 1984 Chevrolet K1500
Rocker arm come out on jeep chrysler 3.7 eng
A rocker arm is the arm that sits on top of the valve stem and connects to the push rods 'the push rods sit on the cam so when engine is running, the push rods go up and down in a timed sequence and with the rocker arms, open and close the inlet and exhaust valves. the rocker arm is located inside the valve(rocker)cover .If the rocker arm gets loose or comes out.
Check the nuts on the shaft which holds the rocker arms.either the shaft or nuts are got loose.They need to be tightened.Don't make it too tight or too loose.  Too tight,and they don't flutter right. Too loose,and they allow the rocker arms to wiggle out of whack. Other possibility can be  something is broken, bent, collapsed, or out of adjustment.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 Jeep Liberty
I have a craftsman lt 1000 w/brigs&straton 17 horse engine i replaced battery & starter but the engine turns over slowly but wont start the battery is fully chaged Im a good mechanic but this has...
It sounds like the compression release is not working,it works by opening the exhaust valve during engine cranking.For the compression release to work the valves have to be adjusted,especially after the engine is broken in.Set the engine to top dead center on the compression stroke,the exhaust valve should be set to .004 and the intake to .002. I think you will find the exhaust valve is way too wide which is causing the hard crank problem.Set the valves by adjusting the nuts on the rocker arms,it should be a torx set screw located in the rocker arm.First back the torx screw out about a turn then hand tighten the rocker stud with the feeler gage in place then tighten the torx screw down to lock the setting.
Aug 05, 2009 | Craftsman Garden
Rattling in engine
My car had been worked on by its previous owner and he replaced all the rocker arms,valves, and push rods, but didnt put the head on perfect and it caused one of the rods and the rocker arm to break to a exhaust valve and created a banging noise that made my car sound like a diesel. I hope I understood your question.
Jan 30, 2009 | 2001 Ford Explorer Sport
OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Logo
Top OTC Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an OTC Hammering Expert? Answer questions, earn points and help others
