Question about Husqvarna 362 365 371 372 Aftermarket Carburetor Carb
I installed a new after market gas tank on mi 365 huski when i start it, it runs at full throttle, with and without the throttle cable attached
  • Husqvarna Master
  • 1,169 Answers
Recheck your assembly...Something is either has the carburetor throttle plate held open or you have an intake air leak. Nothing to do with the tank other assembly problem.
Posted on Dec 15, 2014
Lx288 mower quit running I thought it was out of gas so filled with gas started up but wouldn't keep running.
  • If unit will not run without choke , the main jet in carb is clogged and the carb needs to be cleaned out.
Nov 07, 2015 | Garden
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Husky model 36, 16 in. bar, over oiling, non adjustable pump, will pump out a full tank of oil on about 3/4 tank of fuel, everything is spotless and dont have a clue on how to fix it.
The biggest problem with oiling on this machine was always under oiling, the pump is a fixed capacity so it should be impossible to over oil, it is more likley leaking from around the oil pump pick up and delivery hoses, or from the oil tank breather.If all is ok there then it is going to be a replacment pump.
May 11, 2011 | Husqvarna Operator's Manual 365 372xp ...
How much oil do you have to mix with fuel for a Husqvarna 365 special chainsaw?
50:1 is the fuel to oil ratio. Most oil bottles have dispenser guides for a gallon of fuel. Be sure to use a modern synthetic saw oil and fresh gas. Shake the container thoroughly each time just before adding fuel to the tank to prevent oil starvation. Hope this helps!
Nov 13, 2010 | Husqvarna Operator's Manual 365 372xp ...
I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Jun 06, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
2003 Toro 14-38Z will not come up to full power
Hey..my name is Keith..try disconnecting the throttle cable and moving the throttle on the carb with your fingers..and if it makes max power..then it has the wrong throttle cable on it..but if there is no change in power..then i would suspect the govener..if this dont help..please write back
Jul 06, 2009 | Garden
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna 362 365 371 372 Aftermarket Carburetor Carb Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
