Question about Pioneer Televison & Video
I have a Pioneer DPD 505 PG Plazma. It tuns on, I have sound, but the picture takes sometimes up to 45 minutes to appear and become clear.
I have taken the back off and there are no apparent signs of a bad capacitor. Any ideas
    Top Expert:
  • Pioneer Master
  • 75,311 Answers
Contact the authorized service centre for Pioneer. If Va or Vs voltage to display panel differ from the stated value, this should happen. These voltages will be marked at the silk screen at the bacl of each Plasma display, and it should be very accurate, in case of all plasma displays. These two voltages will differ to screen to screen; and will be marked as stated above to all plasma display panels. Adjustment to this voltage have been provided at the main power supply regulator board to these TVs too.
Actually, adjusting these voltages is a skilled work. So; It will be best to contact either any service technician or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 15, 2014
What settings should I use for playing Xbox on my VX2370Smh-LED monitor?
First, if you're not familiar with it, remember the key to clear pictures with LED and Plazma tv's is FRPM or frame refresh rate per minute.Usually, the higher the better, but the norm is between 40-60 FPM(frames per minute)
Apr 16, 2014 | Video Game Consoles & Games
Two tone screaching sound
In most cases the cause would be bad capacitors in the power supply. You can get repair kits from sites like www.TvRepairKits.com to fix this
Oct 07, 2012 | Televison & Video
My pdp r04u media reciver red and green ligth not blinking only stady lit when i hook up my plazma with laptop i get green light blinking no picture just i want to know what happen my pdp-r04u problem
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
Dec 14, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
DEAR SIR PICTURE NOT CLEAR WHEN TUN TV ON BECOME CLEAR AFTER 15 MIN THANK YOU
Try connecting any other device to the TV to confirm the issue. Try resetting the TV to the factory settings.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony KP-53S65 53" Rear Projection...
Diagonals lines appears on screen and becomes more brighter
With HV variation the color will not be good. Sometimes I have heard that the screen resistor causes this.
Dec 29, 2009 | Konka K2568U 25" TV
Pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Mitsubishi medallion 65" hdtv
the dm module power supply is developing leaky capacitors and will eventually cause the set to not come on at all. this may also be causing the snowy picture if you are useing the digital tuner. The dm module will require repair to resolve these issues.
Nov 29, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
