Question about Element Televison & Video
How do i change the backlight board on a element Model ELEFT466 led tv
    Top Expert:
  • Element Master
  • 75,283 Answers
You disassemble the set to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations
Posted on Dec 15, 2014
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Have an Element LCD model
Hi Jeramy.
These TVs are indeed re-branded Polaroid. You will not find the service manual under Element. You must find the equivalent Polaroid TV.
The Polaroid Flx-3202 is the same as element flx 3202 and 3212 the FLM-3237 is slightly different. Element were re-branded for Circuit City.
Polaroid service manuals won't be a great help, they are written to do board swapping. This TVs are cheap, and board swapping is all the repair that Polaroid ask the technician to do.
The service manual for 3237 is available on the Internet, but it is quite different, check if the two units have the same 37 pins sub, that is the part to be tested if PSU is OK, and there is no power to display (user upload Here Polaroid Service Manual-no t a great help). The other two are not available. Service manuals and bulletins can be ordered through Polaroid service contact.
When inverter and PSU are integrated, you check PSU voltages. There should be a control line from main board (or circuit). It may be passing through a sub board. If you have sound and LED on the AC main and DC-DC sections of the PSU should be OK, in DC-DC, check if there is power to the section going to the backlight (it is not a proper inverter). If that section has power in and no output, then the fault is likely in there.
If PSU is OK, a main failure is possible, but uncommon, the faulty part when PSU works well is the LCD panel.
Hope this will help.
Bye .
Ginko.
Posted on Mar 23, 2011
Hitachi LE55A6R9A has sound but no picture. Passes flashlight test. No LED backlights appear visible at all. Trying to determine whether to start replacing boards or LED strips first.
The led driver may be on the main board or on it's own board. Led strips don't fail all at once so if you had a dark area of the picture then I'd suspect a led strip. TV Parts Universal TV Stands DLP Chips ShopJimmy This is the place to get parts.
Feb 13, 2018 | Hitachi Televison & Video
I have an element tv that isn't displaying picture only sound.
Most likely it's the LED driver. It could be on the main board or the power supply board. These people can get you the correct parts: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 16, 2017 | Element Televison & Video
My element tv has no picture. (it can be seen with flashlight test) will a power supply repair kit fix this issue?
This is usually not the power board. the LED strips fail and you have 55 LED bulbs in the back light. It is not an easy fix because the display is glued to the bezel and if you don't take extreme care when working on it, you crack the LCD display.
Jan 19, 2017 | Element Televison & Video
My Element 46" tv ELEFT466 has sound, but no picture. The flashlight test shows a picture. I'm told this model doesn't have an LED Driver. Is it part of the Main Board? What should I replace? Thanks!
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 13, 2016 | Element Televison & Video
Element 60in. backlight not working... Changed power inverter. What is next fix
Landy, Check the attached vids. instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 03, 2016 | Element ELEFT405 40" LED TV 1920x1080, 60...
I have an ELEFT466, I did the flashlight trick and I have a picture on the screen but no backlights, I could use some help locating the board that powers the backlighting, thanks!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jun 11, 2016 | Televison & Video
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
Dec 26, 2015 | LG Televison & Video
Red STANDBY light comes on when plugged in...then Blue power light comes on when tv is turned on, but theres no picture OR sound...what is the problem?...
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 15, 2015 | Element Electronics Televison & Video
How do I repair nonfunctioning backlight?
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 03, 2015 | Element Electronics Element 40" LED 1080P...
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
Televison & Video Logo
533 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
