Question about Crock Pots & Slow Cookers
What do i do?i was using my bellini electric pressure cooker to cook beans and it turned off itself even when connected.
I made sure it was connected well to a power source
2 Suggested Answers
SOURCE: I have just purchased a Bellini electric pressure
From what I have read your not alone. I'm getting the same beeping and my searching led me to your question. I haven't found anyone saying it has caused them a problem but I haven't found anything that explained it either. You would think the manual would say something about it beeping!
Posted on Jan 10, 2011
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Can I use my cook essentials pc400 programmatic pressure cooker for canning green beans?
Yes you can. The idea of pressure canning is to raise the temperature to above 100'C, 212'F. The higher temperature kills food borne organisms and bacteria.
Personally, as a chef, I would not can green beans as you will lose all the colour and any vitamins that were present by the long cooking at high temperatures. I would blanch them in boiling salted water and then drop them into ice water to set the colour and arrest cooking. The shake of the water and freeze them on a tray. Then put them in a freezer bag.
Jul 07, 2015 | Crock Pots & Slow Cookers
I am using my pressure cooker for the second time. It is not getting up to pressure and it is making a whistling sound. What is the problem
Remove the lid and make sure the gasket is in the right place. Then place the lid on again, and make sure the pressure valve is set to closed.
Here are the Wolfgang Puck manuals, if you're lacking one. Also on that website a great place to ask any basic pressure cooking questions.
http://www.hippressurecooking.com/category/manuals/wolfgang-puck-hsn/
Jan 01, 2014 | Wolfgang Puck Electric Pressure Cooker...
Oxtails
The pressure cooking time for Oxtails is 45 minutes at high pressure. Here is a detailed chart with cooking times for all types of pressure cookers:
http://www.hippressurecooking.com/pressure-cooking-times/
Jun 21, 2013 | Wolfgang Puck Electric Pressure Cooker...
Presssure valve to be turned off or on when using pressure cooker
pressure cooker cooks by the pressure inside the cooker.
So you need to put those on when cooking.
The excess pressure will automatically drain off.
Jun 12, 2012 | Nesco Electric Pressure Cooker
It seems that my Rival crock pot is cooking too slow even on high setting. It has not been used excessively. A smaller one I used years ago cooked whatever in the stated amount of time per high/low...
Hello, Calexander58 -
The heating element for your crock pot may have failed.
You can test it to determine if it comes up the to the proper heat.
Follow these steps:
* Make sure you have the kind of cooking thermometer which can be used to take the temperature of liquids, like one for candy making. If you do not have one, you may be able to borrow one from a relative or friend. Otherwise, you will have to purchase one.
* Fill your slow cooker with water halfway to the top
* Turn it on to the lowest setting and cover for 8 hours
* Do not remove the lid during the full 8 hours
* Remove the lid and immediately take the water temperature
The water temperature should be 185 degrees Farhenheit.
Information source:
How To Test Your Slow Cooker
https://www.spendwithpennies.com/how-to-test-your-slow-cooker/
If the water temperature is less than 185 degrees F, it is time to replace the slow cooker, if it is no longer covered by the manufacturer's warranty.
Jan 13, 2018 | Rival Crock Pots & Slow Cookers
My bravettii slow cooker would not cook baked beans they cooked for 18 hrs total 6 hrs was on high and 12 hrs was on low and the beans are still not fully cooked it never came to a boil is there...
I can't solve your problem but I can sure relate. I am having the same problem with my Bravetti Pro (it's far from Pro - it should be called Bravetti Amateur) I tried cooking a small ham with cut up potatoes recently, and after 11 hours cooking at the medium setting, the potatoes were not cooked. I got this thing as a gift about a year ago, and although I've only used it a few times, it never seems to cook properly. Mine was purchased at Canadian Tire and although I don't have a receipt, I think I'll try to take it back. Good luck with yours!
Tom
Feb 08, 2011 | Bravetti PC107HA Slow Cooker
I have just purchased a Bellini electric pressure cooker. I am trying to find out if it is normal to be beeping during the cooking operation
Dec 26, 2010 | Wolfgang Puck Electric Pressure Cooker...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Crock Pots & Slow Cookers Logo
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
