Dometic RM2193 Compact Refrigerator With Ice Box
Problem for Dometic RM2193 Compact Refrigerator With Ice Box
Gas side of fridge works perfect all day, stops during night!
By douville on Jul 06, 2009
I have a 1994 RV with a Dometic RM7030 side by side. It has AES and really works great when transferring. I mostly run on gas because of no shore power, but I do have a generator. It works flawlessly on electric and for the most part on gas too. Awhile back, I had trouble lighting on gas and there was a pile of rust built up under burner/ thermocouple area, so I cleaned out the rust and everything seemed normal again. Now during the wee hours(3-5 a.m.) it shuts down. It relights usually without too much trouble,1-2 tries. Could the thermocouple be the culprit or is the rust(wherever it's coming from) part of the problem? Is this rust normal? I'm thinking rust can't be good. Thanks for any help you can give me!
Best Solution
posted on Jul 30, 2009
Very Helpful)
VtToolMan
Rank: Guru
Rating: 97%, 620 votes
Sounds like you have some blockage issues and the venturi tube and pilot may need a more complete cleaning. It's possible that the supply pipes have rusted enough on the inside that you're getting small rust particles in the gas and thus into the fridge. You may have to replace the supply lines to resolve this, but...
...rather than 2nd guess what's happening, here's the a link to the diagnostic service manual for your model. You may have to enter in a code to access it once on the website, but this manual will help you troubleshoot your fridge like a pro.
http://gasrefrigeration.net/dom_techdata/7030_7732SM.PDF
Hope this helps and you solve the problem. Best regards!
Comments:
Jul 30, 2009
- Forgot that you mentioned you have the AES on your unit, so here's the AES manual too, just in case you need it.
http://gasrefrigeration.net/dom_techdata/AES_SM.PDF
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dometic RM2193 Compact
Questions and Unsolved Problems for Dometic RM2193 Compact
Do you recommend Dometic RM2193 Compact Refrigerator With Ice Box?
Answer
Answer
Dometic 2193 works on AC and DC but not LP. Doesn't want to light. LP tank is full. Tried to light... (More)
Answer
I struggle to get any temperature lower than 50 degrees.
Answer
i havebrand new dometicrm 1350 refrigerator in my trailer when frige is in gas mode and i traveling... (More)
Answer
my dometic rv refrig is not working on electricity. when it is cut on, the light comes on as if it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
in San Mateo, CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
