How do I change my input to a DVD player on my rca 32v520t without a remote?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Get a universal remote or your infra red smart phone
Posted on Dec 15, 2014
  • 46 Answers
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Posted on Nov 08, 2007
SOURCE: lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter?
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Posted on Jan 26, 2009
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
romsky79
  • 822 Answers
SOURCE: can i change the input settings without the remote
pls check from channel one to zero you can see AV input.
Posted on Aug 17, 2009
  • 93 Answers
SOURCE: change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Posted on Sep 17, 2009
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
My remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
Nov 15, 2009 | RCA RCU300WBL Remote Control
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Hooking up a DVD Player with NO remote
Some TV's will let you access inputs by going through the channels to the very end and see if it works.
Jul 29, 2007 | RCA F25674GY 25" TV
Televison & Video Logo
Top Televison & Video Experts
