Question about Kitchen Ranges
EO- F2 stove accubake duo stove will not come on keep make a sound pit
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Igniter shorting on gas stove
Posted on Dec 15, 2014
jsrock516
  • 5911 Answers
SOURCE: EO F2 code
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Posted on Nov 12, 2007
protek480
  • 1714 Answers
SOURCE: Hi, I am getting an error reading on my whirpool
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Sep 20, 2009
Testimonial: "Thank you so much! I will check around for reasonable prices to get a new keypad installed. I really appreciate your expertise. "
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 28, 2009
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
iwillfixforu
  • 619 Answers
SOURCE: Whirlpool Accubake F2EO
F2E0 is shorted key pad. You will need to replace keypad if the power shut down and reset does not work.
Posted on Mar 11, 2010
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
My whirlpool gold accubake displays an eo f2 light, what does that mean?
Disconnecting the power to an appliance resets the control module.
Feb 17, 2015 | Whirlpool Kitchen Ranges
Mar 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Error Message: EO -F2-, but I don't have a manual
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Mar 04, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
