Question about Samsung Office Equipment & Supplies
I have a Samsung printer DIRECTS-fBM283x series that needs a password - can you help
Trying to connect to the printer & we can see it as a wi fi but needs a password
    Master:
  • Samsung Master
  • 551 Answers
Dear
The same password, set for the wifi router.
Thanks.
Posted on Jan 31, 2015
SOURCE: Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Posted on Apr 20, 2009
SpideRaY
  • 687 Answers
SOURCE: Can I connect wirelessly to this printer from my laptop
If this printer has Wi-Fi then yes you can connect to your router.
The printer must have an internal Wireless PServer it will have a Node Name this is what is needed to connect to the Router. If your router is set for Wireless and the SSID is working (ie no wirless isolation) then when you set up the printer driver it will ask you to connect to the router via an ethernet 100MB patch cable first to load the correct type of port for the printer drive, you only need do this once.
Then if the printer is set to boot in WLAN mode it should get an IP address via DHCP on your router.
Hope this helps, please rate my advice I will post more help if needed just add on to the end of this post.
Posted on Oct 15, 2009
  • 3278 Answers
SOURCE: I am attempting to wirelessly
Hello.
First, delete your printer icon in Printers and Faxes, restart your laptop, then follow the Easy Install instructions and prompts. Choose the network printer connection and continue.
Hope this helps..
Posted on Oct 12, 2010
  • 132 Answers
SOURCE: I have Windows XP. I
In Windows XP:
Start/Settings/Printers and Faxes
Right click /Properties
Check Port tab
If the printer port connect to USB, install another instance of printer, connected to WiFi
Posted on Nov 07, 2010
  • 1082 Answers
SOURCE: We bought a Kodak 5200 series wi-fi printer. It
The problem may be tha the prinrt does not support the N protocol. Only B or G.
PC Connection Hi-Speed USB,
IEEE 802.11b,
IEEE 802.11g
You need to enable G in the router in order to connect the printer to it.
Posted on Jan 26, 2011
How do i get a signal on my galaxy prime core I cannot get internet
Hi Christopher, If no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone and tap "SETTINGS" and tap "CONNECTIONS", Then tap on "Wi-Fi" and make sure it's switched on(should be a slide switch there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on that WiFi setting and a small window opens for the password, Type in the pass word tap "OK" and you're connected... Below is a link to a short YouTube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
May 08, 2016 | Samsung Galaxy Cell Phones
Can I hot spot this phone to a wi fi
Hi Shelagh, If you're trying to connect to your home Wi-Fi The password is on the back of the modem, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
Apr 03, 2016 | Samsung GT-S5310 Galaxy Pocket Neo...
How do I find Wi fi passwords?
Hi Andrew, If you're trying to connect to your home Wi-Fi The password in on the back of the modem, Write it down then go into your phone/tablet settings and click "CONNECTIONS", Then click on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens asking for the password, You're connected... Bellow is a link to a short youtube video explaining pretty much the same thing..... I hope this helps...
https://www.youtube.com/watch?v=8XurHgNoZhs
Mar 30, 2016 | Tablets & eReaders
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
Hi tariq,my wifi is not working,what i do
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. The internet connection is located in the system tray in the bottom-right corner of the screen. The icon looks like a series of rectangles that increase in from left to right. Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks. Choose a Wi-Fi network you want to connect to and select "Connect." Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network. Click "OK." Hope this helps.
Dec 09, 2012 | Computers & Internet
No encuentro el wifi
google translated
I find the wifi
This could be located on the upper row on a laptop it will have the radiation look (((·)))
The icon looks like a series of rectangles that increase in size from left to right.
Click "OK."
Hope this helps.
Nov 27, 2012 | Compaq Armada 1750 Notebook
My samsung netbook n150 plus will not connect to the wifi
This is located in the system tray in the bottom-right corner of the screen.
Click "OK."
Oct 31, 2012 | Samsung Computers & Internet
Connecting a genbook to wifi
Click "OK."
Oct 11, 2012 | Computers & Internet
My samsung star wifi can not connect to my router
1. Tap the "Menu" button from the home screen of your Samsung Star phone.
2. Tap "Wi-Fi" and select the "ON" option.
3. Select the Wi-Fi router you want to connect to from the list available Wi-Fi networks.
4. Enter the case-sensitive password to connect to a secured network. Your phone will only prompt you to enter a password if connecting to a secured network.
5. Wait while your phone automatically connects to the Wi-Fi router.
and enjoy your wi-fi connection.
Aug 10, 2012 | Samsung S5230W Star WiFi GSM Unlocked Cell...
57 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
