PYE Washing Machine AWM800 won't wash/spin. The drum seems very loose. Could it be the springs and the belt slipping?
  • John
    John Dec 15, 2014
    No grease at all, it just seems it dows not wash at all but the sound is like it is washing.
  • Chedoke_27 Jan 05, 2015
    Can you hear the solenoids or hear components turning on/off such as the pump? Does the drum fill with water?
    Problem Solver:
  • 8 Answers
Have you noticed any discolouring or grease on clothes coming out of the wash prior to noticing this problem? Has your washer been particularly noisy during spin cycles before not running at all?
The outer casing on most washers can easily be removed to get a better look. If you notice grease or oil after removing the cover, a good possibility is that the bearing has broken. I have personally experienced this, it ended up being more beneficial to purchase a new washing machine in my situation.
It will do no harm in doing some further investigating in this situation, just unplug the washer before taking the cover off.
Posted on Dec 15, 2014
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Kitchenaid quiet care washing machine
not enough information. there may be a loose or broken drum spring, or the belt may be loose and or worn. If its a two speed one of the gears may be worn.
Dec 31, 2011 | KitchenAid Washing Machines
PYE Washing Machine AWM800 won't drain or spin, says error E2
Hello
This is a drain pump error code.The pump is either jammed or clogged.It will need to be removed and cleaned out.
Jun 19, 2011 | Washing Machines
Everytime I use my washing machine, I get the E3, then dc messages.. also, my belt (for the spin) seems as if it is slipping and can't turn the washer drum over... Then, after I can't take the running...
You get an error if there is something wrong with your machine, now that your washer drum doesn't turn and you are hearing a noise, the possible cause is that the belt alreadi slipped out, if you have the access of opening the back panel where you can see the inner part of the machine, try to replace yoour belt with a new one and install it, it is easy, it only take an adjustment of the bolts and screw, try not to tighten it too much.., make a little loose so that the belt can play.
Aug 25, 2010 | Samsung WF328AA Front Load Washer
Is the motor supposed to not be fixed to tension
The motor is spring loaded to keep tention on the belt. The belt is designed to slip. When the washer is full of water the motor starts at 1725 RPM and the belt is a little loose. As the drum empties its water the belt gets tighter and the speed picks up to spin the water out of the cloths. If the cloths are not comming out as dry as they should, replace the belt. As the belt starts to wear it becomes shiny and doesn't grip the pully properly and slips too much.
I hope this helps.
Jan 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Front loading washing machine will not tumble or spin
This sounds like a drive belt porblem. The belt that connects the drum motor to the drum has slipped/broken/worn out. A new drive belt will most likey fix this one...
Alternately, a loose or broken pulley. I don't suspect a bad motor, since you say you can hear it clicking and whiring...
Jun 10, 2009 | Washing Machines
G E space saver washing machine doesn't spin
Call GE answer center 1-800-626-2000 ask for tech help, Have Model # off your data plate ready,
May 09, 2009 | Washing Machines
Drum not spinning & springs wrong way round?
To replace the belt hold in place on motor & feed onto pulley. The springs are on correctly but it seems one of the suspension legs is not doing its job. This may have occured when turning upside down & would explain distorted door seal. Thanks again for using fixya.
Nov 29, 2008 | Washing Machines
Washing machine
yeppers..belt, motor or tranny...one of em is unhappy..inspect it with power off, and see what's loose.
Mar 13, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
