How do you reset the motherboard on the comfort heat alot heater
  • darlene grabo
    darlene grabo Dec 15, 2014
    it was working fine then it now showing 88888 then switches to 2.00 then when i press enter for temperture it goes back to flashing 8s please help
Comfort-Aire REG-183 18,500 BTU Window Air Conditioner & Heater cuts on and off when not set to auto on heat only
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Bulance AC Cleaning Repair Services
Apr 04, 2015 | Comfort-Aire Heating & Cooling
How do I reset my Comfort Zone heater?
The top light is coming on but the fan isn't working
Feb 20, 2015 | Comfort Zone Heating & Cooling
How do I reset my Comfort Zone Heater Model CZ20118
no sign of power ===main power line or power switch may be defective,,,if u want to reset===power offf main power & wait for tan minutes
My Comfort Zone Infrared heater by Earthwise is showing two different faults on the display, ao5 and doFL, what do they mean?
this means if it does not reset by pushing up,down,enter and clears and no heat then the main control board is shot i have 2 in my shop and the capacitors have popped
Oct 30, 2010 | Heating & Cooling
My comfort zone is not heating I had a infarared bulb that went out replace the bulb the heater still want come on it is hard to get techical support to tell what's wrong.
The bulbs on the older (pre-fall of 2010) Comfort zone heaters are in pairs... if one bulb of the pair is burnt out the other will not work. Also they are not easy to line up when replacing them back into the recepticle...they must line up perfectly to work.
Oct 05, 2010 | Comfort Zone NEW 09 Electric Portable...
Looking for a Comfort Glow Kerosene Heater Manual. Model #PHS/D
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Jan 03, 2010 | Desa International Comfort Glow Infrared...
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
