Question about Hotpoint Washing Machines
I have a brand new Hotpoint (GE) dishwasher model HDA2100H35CC that has not drained since the install just a few days ago. The solenoid can be actuated with no resistance manually, and the armature l
Manually actuated solenoid valve to ensure its not stuck or inoperable, disconnected drain from sink drain assembly and blow air back into dishwasher with no back pressure or obstruction, verified all electrical connections tight and secure behind front access panel
    Sergeant:
  • 248 Answers
You may have forgotten to punch out the plug on the drain connection where you connected the drain hose to the garbage disposal or drain. best luck to you.
Posted on Dec 15, 2014
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
Hotpoint GE Household Microwave
Well, I think you should get a brand new one.
They do not cost as much to replace these days and it might be safer.
May 11, 2017 | GE Microwave Ovens
The water won't drain out of the bottom of the dishwasher.
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control sector(board)
Oct 07, 2009 | Hotpoint Dishwashers
My hotpoint HDA3400G is not draining and i am unsure if the problem is the dishwasher or a clog in my plumbing.
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 25, 2009 | Hotpoint 24 in. HDA3400G Built-in...
GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
The GE diswasher is filled with water even when the dishwasher is not on. if i shut of the water to the dishwasher this does not happen. What is the problem.
Is this the dish water from the previous cycle...or is it fresh water..if not it may not be draining...here are some tips for this issue....
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Nov 23, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Nautilus not draining water out
If the pump is not running, it could be the pump or the timing switch. My GSD2600G00WW would not drain. Wash cylce was running fine. I have just taken out the solenoid attached to the pump and the solenoid is burned out. Will replace tomorrow and see if that does the job. On line price for a new solenoid is about $35.00
Oct 16, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Washing Machines Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
