When I push the burn button it shows a box that says " adjust trim points" 100% then it ejects the disc and says it is having problem writing to the disc with no options or error code you could look up and find out how to fix the problem just an OK BUTTON like o well we tried I guess your screwed feeling what is so odd is the videos that won't burn to the disc had done just fine three months ago . No problems
Ikarus
  • 10 Answers
SOURCE: No valid disc
the codes might have got switched somehow (region codes.) go to this site www.videohelp.com/dvdhacks.php follow the instructions.....I hope this helps!!!!
Posted on Jul 24, 2007
SOURCE: DVD player reads open and the when I push the play button it reads invalid key
I am having the same issue with Toshiba SD-P1850
Posted on Dec 26, 2007
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
SOURCE: It keeps ejecting the disc and saying disc error
Now what this joker isn't telling you is that the 'hack' below actually resets the player to factory defaults. It just worked for me perfectly.
Now you might have to go back into setup and readjust some of your settings. (i.e. freq response)
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
Posted on Apr 13, 2009
steven_mower
  • 9 Answers
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Posted on Jul 21, 2010
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
I'm having problems ejecting cd's from laptop after they're done burning.
Hi
If you go into the computer and open it look for the cd/dvd drive
highlight and right click it and go down to the properties
now click on recording up in the top right hand side of that box
then go down to and put a tick in the box where it says
Automatically eject the disc after a master burn then restart the laptop
this should then automatically eject after a burn
if it don't then
click on your computer icon
it should open it up and show you your hard drive/s
also the cd/dvd drives
if you highlight the cd/dvd drive then right click it and go down to eject hopefully this will eject it
also there is a small pin hole just beneath the push eject switch on the drive itself if you push something thin in there gently but firmly it should also eject the drive
hope this has helped you
please let us know if fixya has fixed it for ya
Jan 30, 2011 | Dell Inspiron 1545 Laptop
I have never burned a CD. I have need of burning two tonight. What do I do?
are you burning a cd or dvd? burning a cd is pretty easy...windows will do most of the work for you. put a blank cd in your cd rom/ dvd burner drive. it will ask you what you want to do with the blank cd...vista usually asks you to format the disk...select ok.....a blank box will pop up....drag and drop your files to be burned into the blank box.....once you are done putting your media onto the disc....eject the disk...before the drive opens a box at the bottom of the screen says that the disc is being prepared for use on other computers. when it ejects, it should be done....you can try to put it back in to the cd drive and see if your data/media files are on the disc. ......now burning a dvd is alot more complicated....do you have software for burning dvd media? if you do, they have help me files and tutorials........some more good advice....youtube also shows good tutorial vids on burning. just type in "burn a cd or dvd".
Oct 12, 2010 | Computers & Internet
Cant make a back up of my dvd's for the kids to use. with shrink and decripter. when i do now it says, when i play it, it says no menu.
Step 1
Be sure to erase all data on the disc, if media is rewriteable, by going up to the "Recorder" drop-down menu and clicking "Erase Rewriteable Disc." A box will pop up on which you need to choose the correct recorder from the top menu, quick or full erase (best option), and a maximum erase speed is fine.
Step 2
Choose your recorder drive on the top right drop-down menu on the main screen. The drive icon next to this menu allows you to set advanced options. (Not needed here.)
Step 3
Click on the "Burn" icon in the middle of the main toolbar. This opens up the "Burn Compilation" box.
Step 4
Click on the "Multi-session" tab on the "Burn Compilation" box. Choose "Start Multi-session disc", if the disc is to be added to later. Choose "No Multi-session disc," if the disc is to be completed with the current burn. The other options are good at the default settings.
Step 5
Click on the "Label" tab on the "Burn Compilation" box to give the disc a title that will be seen in the drives list, such as Windows Explorer, when the disc is loaded. Choose "Automatic Disc name" and enter the desired name without spaces. For spaces, add underscores (shift+hyphen).
Step 6
Click on the "Burn" tab on the "Burn Compilation" box to set desired burn and writing actions. "Determine maximum speed" lets Nero determine the recorder and disc speeds, if they are unknown. "Simulation" performs a test virtual test burn to see if all goes well. "Write," of course, burns the disc. "Finalize disc" means that the disc will be burned, so that no more can be burned on it. (For the example, check the boxes for "Write" and "Finalize disc," which is probably already checked.)
Step 7
Set "Writing speed," if known, "Writing method" as "Disc-at-once" and "Number of copies".
Step 8
Click the "Burn" button at the bottom on the "Burn Compilation" box to begin the actual burning process and the "Writing to disc" window will open.
Step 9
Check the "Verify written data" box on the bottom left of the "Writing to disc" window. This will have Nero read the disc, after it is done burning, to verify that all of the data has been properly burned to the disc. This is an important optional step, especially with really important data. If all goes well, a box will pop up stating that "Data verification completed successfully."
Step 10
Run the disc in a drive or DVD player to make sure it runs correctly. If it does, the original files on the hard drive may be deleted, if desired.
Dec 11, 2009 | Computers & Internet
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
X Box 360 will not open when pushing the silver button to load ga
Try tapping the drive front after pressing the button. If this dont work and the green light is flashing after pressing the eject button then the belt inside the dvd needs to be replaced.
Jan 12, 2009 | Microsoft Xbox 360 Console
How do you burn a cd on the travelmate 290 ?
Windows XP CD Copy Windows XP has CD-Recordable (CD-R) disc burning support for most CD writers.
8b118c9.gif First set your CD-recording options:
  • Open "My Computer"
  • Right-click your CD-R drive and select "Properties". See figure BK-1.
  • Select the "Recording" tab (if this tab isn't available, your device doesn't support CD burning).
  • Check the box to "Enable CD recording on this drive".
  • Select the drive to hold the temporary files (before the system burns a CD-R disc, the system writes the files to be recorded to an intermediary area - this area must have enough free space to hold an entire CD's content).
  • Select the CD recording speed (Fastest, 4X, 2X, and 1X).
  • Select whether to eject the media after recording.
  • Click OK.
Perform the following steps to record to a CD-R:
  • Insert a blank CD-R disc into your CD burner.
  • Copy or drag the files or folders to be recorded to the CD-R drive, or right-click on the files or folders and select Send To, Writable CD.
  • After you have copied all the files, select the CD-R drive from "My Computer" and you'll see the waiting files as "Files to add to the CD."
  • Right-click the CD-R drive, and select Write to CD.
  • Enter a name for the CD-R disc, and click Next.
  • The files will be written to the CD-R disc.
  • After the system writes all the files, it will eject the CD-R disc (if you chose that option above).
  • Click Finish.
Jun 06, 2008 | Acer Computers & Internet
Using roxio creator basic v9 when i burn disc its writing to the disc (700MB) without giving free space,i just made a copy of original cd which has 162MB,after writing to new disc,showing 700MB used..
Burned CDs always show as being fully used. That is so users don't think they can just copy files onto it. The way to find out how much free space is to subtract the amt. of space used from the capacity of the CD. Also most CDs are burn-once so after you burn it you can't add or delete files anyway. Only CD or DVD "RW" (read-write) discs allow you to re-use them.
Mar 08, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
