Question about Medi-Rub Medi Rub Body Massager Medi Rub Body Massager
The 4 rubber connectors between the motor and the pad are broken. Can it be repaired?
They all broke. Haven't tried anything.
Model RAX7244EQ1, Will not go in spin cycle, Motor is running but sounds like somthing broke. Could this be a belt ?
This is most likely a failure of the plastic couplers / rubber isolator between the motor and gearcase. This assembly is designed to fail during an overload condition, but they often just wear out over time. If you are mechanically inclined, it's not a difficult repair to make.
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET---
1. Remove console
2. Remove 2 gold clips at rear of top
3. Unplug lid switch harness
4. Rotate the cabinet up a few inches at the rear and pull it straight off
5. Near the floor at the front of the machine, you'll see the pump, motor, gearcase assembly
6. Remove the 2 large metal clips that hold the motor to the gearcase (you might have to disconnect the motor wiring connectors
7. Rotate the motor / pump downward so the end of the motor facing the gearcase is pointing up / out so you can see it.
8. You should see evidence of a failed coupler... rubber and / or plastic pieces
9. Pry the broken plastic couplers off of the motor and gearcase along w/ whatever's left of the isolator (black rubber)
10. Install new parts (probably need to get these at your local appliance repair shop)
11. The tricky part is realigning the couplers and isolator so you can push everything back together. Be patient... once it's pushed back together, reinstall the large metal clips, motor wiring connectors, etc.
12. Put the cabinet back on, being careful that the rear corners are pushed inward so they engage on the base tabs
13. Install everything else in reverse order of removal
14. Plug it in and listen to her purr...
Good luck.
Jan 16, 2011 | Roper Washing Machines
None of the windows work! 2000 Intrigue
if no fuses are burnt and you have new switches installed then it going to be either bad motors or a broken wire in the harness to the driver door switch set.
Aug 11, 2009 | 1998 Oldsmobile Intrigue
Front brake pad light comes on, but the pads are new
It is not the brake computer. The front left inside brake pad is the noly pad with a sensor in it. If the light is on it is usually because the wire connector broke and is now causing an open signal, cauing the light in the cluster to come on. Remove the front left wheel. Remove the connector for the brake pad attached to the shock assembly. Check the terminals for corrosion. The pins must be clean and not blackend or green. The female side connector terminals must be straight and not widened. If you want to be sure you can do 1 of 2 things. Check the resistance of the the 2 pins going to the brake pad. It must be 0 resistance meaning not open. Or bypass the female connector temporarily with a paper clip or wire and start the car. If the light goes off it means the pad is the cause or the connector. I have often seen the wire still holding and not broken completely but when you remove the pad the ridge of the inside of the disk has worn the wire to the point where it broke prematurally. Sometimes just a light tug and it'll break.
Aug 11, 2009 | 2002 Volkswagen Jetta TDI
Check brake pads light on dash
There is a sensor on each of the front (not sure about the rear) brake calipers that indicate via the dash light when brake pads are worn down and need replacing. The wire is probably broken on one or both of the front wheel calipers. If there is enough slack in the wire you can just splice it back together with **** splice connectors and seal with heat shrink insulation. My '02 Passat has had it happen twice, first on the drivers side, repaired wire and light went out, then the other side broke, repaired the same way and haven't had any problems since.
Mar 15, 2009 | 2003 Volkswagen Passat
My stackable whirlpool washer doesn't spin/work
The most likely cause is the motor coupling , its the plastic and rubber parts between the motor and transmission. Try turnig it with your finger.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
Kenmore 110.82984120 Washer fills and washes but wont spin at end
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753. mounts directly to the motor shaft and connects to the transmission, when you ge the part itll be apparrent
Mar 01, 2008 | Washing Machines
Broken part
Gennerally no. Most mounts are now made in Asia and there is no parts support. I and and few others (teletrade.com) cannibalize used stuff for parts, but that's about it. HTH, Geo.
Jan 18, 2008 | Optics
Sanyo tv coaxi wire broke
Let me guess you have broken off your I.F connector ,this is what you connect your cable to on the back of your set,if this is what you are talking about ,you will need to try and repair IF connector or replace your turner.sometimes when this piece is broken off turner is also damaged,there for you have to replace turner.
Dec 09, 2007 | Sanyo DS27910 27" TV
Medi-Rub Medi Rub Body Massager Medi Rub Body Massager Logo
Top Medi-Rub Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Medi-Rub Health and Beauty Expert? Answer questions, earn points and help others
