Question about Dryers
My element flx3211b, has power, when i press the on botton the power indicator changes from red to blue, but unit doesnt power up. Can u help?
Looking for blown fuses, and or possibly loose connections
  • Dryers Master
  • 5,323 Answers
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
my element flx3211b, has power, when i press the o - element-flx3211b-power-when-press-2twpke0famvgldalck04zdql-3-9.jpg
Posted on May 05, 2015
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
What happen to ricoh aficio display 542
A SC542 deals with the fuser unit, it's not warming up to the correct temp. Did you have a power outage? Try to rest it with pressing the "Yellow clear botton then the numbers 1 then 0 then 7 then press and hold the red stop/clear botton till the screen changes. Once it changes turn the main power switch off and then back On..... If it is not cleared you may have a problem with the fuser unit.... Good Luck
May 26, 2012 | Ricoh Office Equipment & Supplies
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Showing error 551
I believe the code has to do with the fuser unit. You can try to reset by pressing the "Yellow" Clear botton then the numbers "1""0""7" then press and hold the "Red" Stop botton till the display changes. Then turn the Main Power switch Off and then back On. If it will not clear you have a problem with the fuser unit and will have to be repaired to clear the code.
Aug 29, 2010 | Ricoh Aficio MP 1600 Black and White...
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
Dryers Logo
66 people viewed this question
Top Dryers Experts
