Question about Nokia 1600 Cellular Phone
Forget the 4 digit code - Nokia 1600 Cellular Phone
    Genius:
  • Nokia Master
  • 1,373 Answers
Hi if you forget the security of your Nokia 1600 mobile then try to reset your phone using default codes like 0000 or 1234 if this codes didn't help to reset your phone then visit sites like Unlocking4Free.com here they are generating master reset code for your mobile model at free of cost ..You can use it and reset your phone then assign new security code for your phone if you wish ...
Posted on Dec 18, 2014
  • 3 Answers
Http://greentooth.xtgem.com/mastercode
Read the instructions carefully then try to generate the code through given link.I have never experienced this problem so not sure.So may work or not.
Posted on Dec 15, 2014
How do I restore Toshiba DVD player SD3990 back to original without password? Forgot password.
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared. "P CLr" appears on the
display for a moment.
3 Enter a new code as shown above to the left (Rating)
Dec 05, 2014 | Toshiba SD-3990 DVD Player
I forget nokia N 2310 secuirty code
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 29, 2012 | Nokia 2310 Cellular Phone
Zip code or postal code for nicaragua
Postal Codes in Nicaragua consist of 7 numbers,with a dash between the 3rd and 4th digits and between the 6th and 7th digits.eg:
050-008-4 050=district 008=block 4=side THERE IS NO ZIP CODE IN NICARAGUA.
REGARDS.
PLZ. DON'T FORGET TO RATE THIS.
Jul 07, 2011 | GPS
Forgot my four digit unlock code
Your phone's 4-digit unlock code is originally set to the last 4 digits of your phone number, and the 6-digit security code is originally set to 000000. Your service provider may reset these codes before you receive your phone. If your service provider has not reset these codes, we recommend that you change them to prevent others from accessing your personal information. The unlock code must contain 4 digits, and the security code must contain 6 digits.
If you forget your unlock code, try entering 1234 or the last 4 digits of your phone number. If that does not work, press the menu key, in most of the phones this will bypass the unlock code screen, and the phone will now be asking for the security code. If you forget the security code, send your unit in for repair to a level three LSC. There could be a charge for this as it is not covered under warranty.
To change a code or password:
  • Press the Menu key
  • Use the Navigation Key to scroll to Settings, and select this option
  • Scroll to Security and select this option
  • Scroll to New Passwords and select this option
  • Select the type of code you wish to change
  • Enter the old code when prompted, then enter the new code
  • If you forget your SIM lock, or call barring password, please contact your service provider.
Mar 05, 2011 | Cell Phones
How to reset security code on panasonic cd player CQ-VD7003U
ID-CODE
ID Code Setting
Prior to operating this unit, it is advisable to assign a 4-
digit ID code for security. Once the ID code has been set,
the unit cannot be operated if the main power supply is
disconnected then re-connected. It is electronically locked
so that a thief cannot use the stolen unit unless that person
knows the code you have set.
The ID code operation must be performed only by the
person to whom the unit belongs.
Generally, it is not necessary to enter the ID code each
time when using the unit if it has not been disconnected
from the main power supply (car battery).
to 4 digits numeric code
default: none
How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until "COMPLETED!" is displayed.
The ID code canceling procedure is completed.
The unit now works without an ID code.
Note:
¡Should your unit ever require service, cancel your ID
code before sending for repair.
¡The ID code setting cannot be eliminated even by the
memory clear function.
¡The inputted code is not displayed for your security.
0 9
Caution
¡Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to use
the unit. In case you forget the ID code, please
consult your nearest Panasonic Service Center.
Dec 09, 2010 | Panasonic CQ-VD7003U Car DVD Player
I forget my security code of nokia ce0434
You may try default phone and security code to remove
ur defalt phones codes is 12345 or 00000 u can use it
Sep 07, 2010 | Nokia 1650 Cell Phone
I did forget the 4 digit code for my remote control URC-3300B02
I can help you with your URC-1030 Universal Remote Control issues.
The One For All URC-1050 Manual and Code List are available here.
For complete instructions on entering the URC-1030 remote codes, please refer to my posted Fixya Tip One For All URC-1030 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-1030 Manual
One For All URC-1030 Code List
One For All URC-1030 Code Search
One For All URC-1030 Reassign Key
May 20, 2010 | One For All URC-1030 Remote Control
My son forgot his security code for his motorola v360. pls help!!
I think this will help....
codes & passwords
Your phone’s 4-digit unlock code is originally set to 1234.
The 6-digit security code is originally set to 000000. If your
service provider didn’t change these codes, you should
change them:
Find it: Press M > Settings > Security > New Passwords
You can also change your SIM PIN or call barring passwords.
If you forget your unlock code: At the Enter Unlock Code prompt,
try entering 1234 or the last four digits of your phone
number. If that doesn’t work, press M and enter your 6-digit
security code instead.
If you forget other codes: If you forget your security code,
SIM PIN code, PIN2 code, or call barring password, contact
Jan 27, 2009 | Motorola Mobility V360 Cellular Phone
Unlock code
hi john_q,
I got a trick to bypass the security code and reset or change the code.
The method is :
1) When u are asked for security code, there is space for only 4 digits.
2) At that time, press and hold menu button(above the directional keys) for 3-4 seconds.
3) Then the gap for 4 digits will change to 6 digits slot.
4) Type 000000 (six zero) and u will bypass the security code.
5) By same process, u can reset or change the security code from the settings.
Repeat this process until u r successfull.
I m looking for ur kind feedback. And dont forget to rate my solution.
Be sure to post a clarification request for ur problem after u got ur problem solved.
SAJAN (sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
May 03, 2008 | Motorola Mobility L6 Cellular Phone
Need to unlock my phone
If You Forget a Code, PIN or Password
Note: Your phone’s 4-digit unlock code is originally set to
1234 and the 6-digit security code is originally set to 000000.
Many service providers reset the unlock code to the last 4
digits of your phone number before you receive your phone.
digits of your phone number. If that does not work, do the
following at the Enter Unlock Code prompt: Tap (MenuButton) to display the
unlock code bypass screen. Enter your security code, then
tap OK to submit the security code.
If you forget your security code, SIM card PIN code, PIN2
code or call barring password, contact your service provider.
Jan 31, 2008 | Motorola Mobility A780 Cellular Phone
Nokia 1600 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
