Question about Kenmore Freezers
I need manual for # 253 9284214
Freezer runs all times sometimes does not freeze
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
My freezer is running but not freezing
Thermostats are usually located in the machine, lower right side facing it but sometimes the left side. More than likely you have a freon leak and the machine is starting to act like a fridge then a freezer.
Jun 05, 2012 | Freezers
True freezer T-35F. outside the door around the seal is too hot. it took a long time for new food to freeze or not frozen at all. fan seems to be running.
You have check if the fan underneath is running? Or maybe it is starting to go bad and only runs sometimes and sometimes it does not?
May 28, 2011 | True 35 cu. ft. / 991 liter Commercial...
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
Frigidaire FP120V Fridge is too warm, yet freezes in crisper
There may be vents that need to be closed and or opened a little for proper adjustment.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
Freezer not freezing
Is it running? You might need to put your ear up to machine, to hear it, They run very quitely.
If not running, could be a bad cold control (thermostat), or defective relay and overload mounted on the compressor body.
If the compressor is running but no cooling, then you're in serious trouble unless,
The unit is 5 years old or newer. In that case you have factory warranty on what is called the sealed system. Contact the dealer in that case for service. Service should be free.
Oct 30, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
69 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
