Question about Pool & Spa
How do i fix my spa in a box pump
Pump won't work
    Master:
  • 742 Answers
First you need to troubleshoot to find out why the pump is not working.
Posted on Dec 15, 2014
Healeyman
  • 1198 Answers
SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Posted on Apr 17, 2009
TheSpaDoctor
  • 10 Answers
SOURCE: maxi flow spa booster pump, buzzing...then cuts out
hi the capacitor needs replacing in the pump connection box, this needs to be exactly the same uF value as the one you are taking out.
Posted on Jul 08, 2009
Coastsider
  • 331 Answers
SOURCE: Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Posted on Apr 14, 2010
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
  • 6 Answers
SOURCE: Spa n a box 6
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Posted on Mar 31, 2011
Our Intex spa pump will not turn on
does the unit power up if not check and test the ground fault safety plug they can fail --if powers up and pump not working then the your problem is most likely the ceramic rod that holds the motor /impeller in place they have a big problem of breaking and intex doesnt sell a separate pump or the replacement rod the following link can show some quick fix but if you buy a brazing / welding rod the same thickness -home depot sell them 9.99 a box you only need 3" and need to clean flux off
Intex spa E95 cheap fix
Jun 04, 2017 | Intex Pool & Spa
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
How do I fix an Jandy ePump?
open up the power box see if still wet dry out make sure communication plug is dry then power everything down reboot and try again if it doesnt work the main board in the pump is no good
May 25, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Recirculation pump not starting
need to check the contacts in the relays themselves.. see if they need cleaned to make better contact.. may use a small fingernail emery board..or fine sandpaper to clean them..unplug the unit first..
Jan 18, 2014 | Pool & Spa
After replacing pool pump # MPRA6F-148L no suction
The pump will only pump water, I assume after the work it's currently full of air?
Jun 05, 2013 | Sta Rite 1 HP StaRite Pump 15" inout...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
SPA PUMP REPLACEMENT
Yes to all - !!!!
Apr 26, 2009 | Pool & Spa
Pump will not work in high speed
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Feb 12, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pool & Spa Logo
62 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
