Question about Lifetime 1221 Pro Court 44" Portable Basketball System
How do I fix a Uneven Lifetime Backboard basketball hoop?
The backboard is uneven. One side of the backboard is more high than the opposite side. How to fix it?
2 Suggested Answers
brandonman24
  • 62 Answers
SOURCE: basketball backboard problem
well it is probably a cheap backboard then. sorry
Posted on Apr 01, 2009
A/C Troubleshoot,Set up gauges on low and high side. Low side reading 200 high side 550. Compressor working fine. No visible leaks. Freon blowing out on opposite side of LP connect? Hot air in car.
Check to make sure that the engine cooling fan or fans are working. Sounds like there isn't any air flow through the condenser. Also it won't hurt to wash out the condenser and radiator.
Jun 14, 2017 | Cars & Trucks
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Cheers
Mikey
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
Broken tempered glass backboard
Garage/yard sales, craigslist. Do you know someone in the neighborhood who hasn't used theirs for awhile, Ask them if they will take $50 for theirs that may be in the way.
Apr 11, 2012 | Microwave Ovens
I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Feb 06, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
E3 error message on Magic Chef wine cooler MCWC44DZ. Can I fix it myself?
Taken from another poster at Home Depot reviews and similiar to what others have found...
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Jun 08, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Basketball pole
Ihave a pole and backboard but my backboard is cracked badly. Would you consider selling yours?
Apr 18, 2009 | Lifetime 3819 Impact 44" Basketball...
Basketball backboard problem
Nov 23, 2008 | Lifetime 3819 Impact 44" Basketball...
Duplexing problem on Konica Minolta Bizhub C650
This is a software thing.  Usually if you use the hole punch in the finisher this doesn't happen.
Try putting the paper in the other direction and see if that fixes it.
If it doesn't fix the problem you will have to run one side at a time.
Sep 17, 2008 | Office Equipment & Supplies
Lifetime 1221 Pro Court 44" Portable Basketball System Logo
126 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
