Question about Tappan Kitchen Ranges
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
The oven button,broiler button, and self cleaning button doesn't beep when pushed and oven wont heat up then screen says "dr"? after unpugging it and then plugged back in I got the error code "F13"?
    New Friend:
The code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Posted on Jan 06, 2015
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have a tappan self cleaning oven KMT-2893-87A
call Sears for they took over Montgomery Wards services and we have the same stove
Feb 03, 2010 | Tappan Kitchen Ranges
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Tappan self cleaning gas stove and oven
Sounds like an problem with the ignition system.  You probably ought to get help on this.  GAS IS DANGEROUS.
Nov 21, 2008 | Ovens
Broiler won't turn off. Error code F-3
hi there,
can you provide the model # off your stove please?
Sep 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
188 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
