Question about AMP Music
Diagram of connecting power amp pv3800 to fx2 32 chan mixer
Nothing
    Top Expert:
  • AMP Master
  • 3,130 Answers
I'm not sure i understand you question? You would come out of the left and right XLR outputs on the board and into the two left and right XLR inputs on the amplifier. If you need more help and the dealer who sold you the gear isn't willing/able to assist you, Peavey customer service is quite good about walking people through problems. You can reach them at 877-732-8391.
Posted on Dec 15, 2014
How do I connect a peavey 32fx mixer to a peavey pv3800 ampflifier
You should be able to connect the XLR l&r outputs to the amp or the 1/4" l&r outs to the amp. Check out the manual here.
http://assets.peavey.com/literature/manuals/FX_Mixers.pdf http://assets.peavey.com/literature/manuals/FX_Mixers.pdf
Nov 03, 2015 | Peavey Music
No power
switched mode power supply and class d amps, take to shop that can work on these, it should of had a 5 year warranty.
Mar 30, 2014 | Peavey XR 1212 Powered Mixer Mixer Powered
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Aug 12, 2011 | Mackie ProFX8 Professional Compact Mixer
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
No sound
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
Jul 24, 2010 | Mackie 1202vlz3 12 Channel Mixer
Music Logo
Top AMP Music Experts
Raymond Richards
Raymond Richards
Are you an AMP Music Expert? Answer questions, earn points and help others
