Question about Coffee Makers & Espresso Machines
I HAVE LOST MY KEY AND THE BATTERS AR FLAT
TRIED EVREY THING BUT THE GRINDER.
My merc 709 won't start
Sounds like dead battery... Is the same thing happening when you jump start the car?
Jan 11, 2015 | Cars & Trucks
Grinder not taking beans
clear of the ground coffee funnel, a flat screwdriver to pry the lid on grinder and then during grinding pull the vacuum
May 30, 2013 | DeLonghi ECAM 23.450 S Espresso Machine &...
The time settings are lost if I leave the computer on battery when turned off. I get F1 and F 12 messages and must reset the time from 01/01/1988. No problem if plugged in.
The problem is a flat BIOS battery. This battery keeps the Date & Time and other laptop setting stored in the BIOS. When the battery is flat then these settings are lost when you switch off the laptop.
You need to replace the BIOS batters thn go into the BIOS to set the Date & Time then you will not have further problems.
Aug 21, 2012 | IBM ThinkPad A31 Notebook
I lost my key to remove lugnut lock. How can i remove it without lock key
You could use an angle grinder to make a flat notch in the top of the lug nut, right across the key pattern. Then use a large impact rated flat blade tip in an impact or other wrench. Depending on the length of the locking lug and how far it sticks out, you could try clamping on vice grip pliers and using a pipe or tube as a breaker bar on them. These tools can be obtained inexpensively from HarborFreight.
Of course, your dealer can provide a new lug nut lock for your car. Just give them your vin number, provided that the same locks that came with the car are on it now.
Hope this helps!
Jun 02, 2012 | 2000 Lexus ES 300
Digital safe. combination isint working. key was lost years ago. urgent that get open grocery money is inside.
I assume you have been able to open it with the key code up till now?
Its possible the batteries are flat. Most digital safes only have access to the batteries once it is open.
If you can access the batteries from outside try replacing them.
If the safe is only a cheap model use an angle grinder to cut it open, or take it a locksmith.
Good luck,
Steve
Oct 12, 2010 | Computers & Internet
I forgot my reset code for the samsung c-170.. can you plz help
the master reset code in samsung is "00000000" or you can reset full setting but you will lost evrey thing on it the code is *2726*3855#
Apr 18, 2010 | Cell Phones
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
IBM Thinkpad 380 ED 00161 and 00163 errors
the cmos batters ar soled at walmart in the watch dep
Feb 03, 2008 | IBM ThinkPad 380ED
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
