Question about Grohe Plumbing
Grohe Shower Head will not work? I tried replacing Grohe Shower head with a non Grohe head & I lost all water pressure to the shower head. I then put the Grohe shower head back on but there is still no water pressure to the shower head. The Grohe faucet has pressure but no water is coming out of shower head. This is an older model that I cannot find a SErial # on. Any suggestions on how to get pressure back up to the shower head? Thank You
    Master:
  • 560 Answers
The water gets to the shower head by the diverter. Check that.
Posted on Dec 26, 2014
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
snap101
  • 117 Answers
SOURCE: water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Posted on Jul 31, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
  • 349 Answers
SOURCE: shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
Posted on May 05, 2010
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Very slow water flow.
If you take off shower head and look inside you will see what is called a water saver. Pull it out and this will give you a full port so more water can come out unrestricted. reinstall shower head and be careful the new pressure does not knock you down.
Sep 25, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Plumbing Logo
207 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
