Question about Bissell Homecare 94Y2 - Bissell Lift-Off Deep Cleaning System
How do you clean the bissel machine from build up of dirt, hair etc
    Master:
  • Bissell Home... Master
  • 894 Answers
HI, it's Jim from Crucial Vacuum!
If you're looking to clean your Bissell vacuum here are some parts you should focus on to ensure proper suction and overall peak performance for your Bissell.
One of the easiest parts to clean is your vacuums brush roll. First thing to do is unplug your vacuum and flip it on its side or back. Notice any debris, such as hair or carpet fibers. Remove these either with a razor, or a scissor. Then, manually rotate the brush roll to uncover any further clogs.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged and this is a simple task to do after you vacuum. And it will make a world of difference for your vacuums performance.
It is recommended to wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
You can purchase a variety of replacement parts for your Bissell vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Dec 17, 2014
  • 4 Answers
I have found the best way to clean buildup of dirt, dust and hair from my vacuum cleaner is to use an air compressor to blow off all this stuff. Strongly advise doing outside and not in any enclosed space. Requires an air compressor with a good length of hose.
Vacuum leaves a trail of dirt
There's a small hole in the center front on the bottom by the brush. Its clogged with hair etc. If you stick your finger in there and remove the debris it will work fine. This just happened to mine.
Apr 06, 2012 | Bissell Lift-Off(R) Revolution(R) Turbo...
My Bissell vacuum was making a loud vibrating sound when it was turned on, so I opened the bottom up, replaced the belt, but it is still making the loud vibration, which it wasn't doing before. Any...
Check to see that nothing is clogging the machine. If you don't find anything, then the fan on the motor may be broken or chipped.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 27, 2011 | Bissell 3910 Bagless Upright Cyclonic...
HI I have a Bissell Pet Hair Eraser it has a very loud high pitched squeal, I have removed the belt & cleaned it with no effect. Is there something else I cn do? Thanks Joe
The belt may be stretched out and therefore, no good. You can try roughing up the surfaces the belt rides in with some 150 grit sandpaper. That may do the trick
Feb 02, 2011 | Bissell Upright Vacuum - The Pet Hair...
My Bissell will not **** up pet hair or dirt
Dirt hair and such will build up in the hoses of that vacum. Take them apart stretch them out and run something through them to make sure they are clean.
The other problem is the filter in the bottom of the cup. At least on some models there is a filter that gets totally pligged with dirt and dust. Take it apart, wash it out and them put everything back together.
Heatman101
Mar 21, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
The bissell proheat is leaving too much water on the carpet
Sounds as though the machine needs a good clean before using again. Remove all the dirt, grease and hair from the transparent areas by removing the covers and then reassembling. Also this can be caused by running the cleaner too fast across the carpet.
Aug 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Homecare 94Y2 - Bissell Lift-Off Deep Cleaning System Logo
85 people viewed this question
Top Bissell Homecare Vacuums Experts
ray gallant
extremebill
Level 1 Expert
Think Crucial
Think Crucial
Are you a Bissell Homecare Vacuum Expert? Answer questions, earn points and help others
