Question about Toshiba Dvr620ku Dvdrw Vhs
From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized.
PROBLEM: [3 of 4 HDMI Video images & DVD recordings vertically pinched.] Progressive: ON & OFF; set to ON. Aspect Ratio: Auto, 4:3, & 16:9; set at 16:9. Inputs L1 & L2; set at L1, Dubbing VCR to DVD. Recording compatible ON. HDMI Format to RGB. [TV & recorded DVD images] are the same; Height correct in HDMI selection 740x480, and [[vertically pinched in 1280x720,1920x1080i, & 1920x1080]]; set at 1920x1080i. DVDs also, vertically pinched when played on another DVD players & this unit. Changed output HDMI cable to a Hi Quality cable. No improvement. Connected 3 different TV's, SONY 50", SAMSUNG (Older 27" & New 55" SMART TVs), still vertically pinched. VHS to DVD works OK except for the 3 HDMI vertically pinched output. Tried different mfg's of blank DVD & DVD-R & DVD+Rs. Purchased DVDs play correctly FULL height in all modes. HELP, JIM jbenham10@cox.net
2 Suggested Answers
SOURCE: Toshiba RDXV59DTKB2 HDD/DVD/VCR recorder.
Ok, this is happening due to the fact that the CODEC FORMAT you recorded in doesn't exist on the player you wish to play it on.. you MUST ensure you encode the DVD in a CODEC that every machine will have... When you Burn a DVD the information is Encoded, with a CODEC, the SAME CODEC is required to Play it back, if the Player doesn't have the particular CODEC as standard, then it simply is unable to play the DVD. Look on the DVD Player and check out what CODECs it can handle, then encode your DVD Burns using that CODEC, and you will be able to play it on any compatible player, Usual formats are MPG4, VOB, DiVx,
have a look below to understand what you need to do.
http://www.webopedia.com/quick_ref/Video_Codecs.asp
Posted on Nov 11, 2010
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I have a Samsung C230 LED monitor and I'm wondering if I can use it with a Roku XD/S in place of a TV via the hdmi cable?
as far as i can tell this monitor is not HDCP compliant ( High Def Copy Protection ) and therefore will not be suitable as a TV monitor. Computers can use non HDCP compliant monitors but TV Tuners, Satellite Receivers, DVD players etc with HDMI are HDCP compliant and must have a HDCP display... HDMI has two formats basically HDCP and non HDCP
Sep 04, 2013 | Samsung Syncmaster 940BW LCD Monitor
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
White screen and black vertical lines over half of la26b450 model tv screen
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
May 29, 2011 | Televison & Video
Symphonic WFR205 DVD recorded but not finalized
I have similar problem. I have recorded all of my old tapes on a DVD-RW disc (lots of time spent on it) and as I wanted to finalize them - it would display an recording error. Recently I purchased a new Sony blue ray player and I realized it would play the not finalized discs. I am still looking for a solution how to record these memories on a PC so I can edit them.
Jan 30, 2009 | Symphonic WV806 DVD Player/VCR
DVD unable to play tv recorded items
If you can see recording on the flip side..it is either a disc patch fix (software) obtained thru Go Video..or find another go video recorder to finalize it..you might try unplugging the unit for a minute or two..and try it again...
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Cannot finalize dvd-r
Have solved the finalized problem by simply looking on the Canon website and read that you have to plug the camera into the wall to do it! If only they simply put this in the manual!!! Goodluck!
Mar 01, 2008 | Canon DC95 DVD Camcorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Display Image Pinched Vertically
I think this is a non-ddc monitor. But I think you right, the monitor is damaged and won't read it's own driver. http://support.microsoft.com/kb/162737/en-us
Jul 11, 2007 | NEC MultiSync XV17 17" CRT Monitor
Toshiba Dvr620ku Dvdrw Vhs Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
