Question about Water Heaters
I have an Amtrol them x trol and I have significant humming through my home, when I check the unit I can feel it vibrating and putting my hand on it reduces the volume of the humming. The humming disappears when we run cold water or flush a toilet.
    Problem Solver:
  • 16 Answers
Most likely the humming is due to a defective or damaged check valve on your water METER and only translates the sound through your extrol expansion tank. The check valve on your meter should be replaced. The noise stops when you run water because the faster flow through the check valve opens it completely. Most likely you have a running toilet or dripping faucet that let's water seep through the check valve causing it to partially open and creating vibration in the bad gaskets on the check valve.
#1 have the check valve replaced
#2 find and repair the water leak
Posted on Dec 20, 2014
  • 68 Answers
SOURCE: pipes humming in house
From your description, I am guessing you are on a deep well with this answer. I think you have an issue with the well pump. To isolate it do this...........
Turn the main supply valve off to the house. Your well tank should have a hose bib on the well tee. Hook a hose up to that and run it outside. Open the valve to the hose until you heard the pressure click on which activates the pump. After the click close the valve and listen for the hum. If it still hums it is the Well and not the piping in your home.
Will follow-up.............
Please rate this response after testing and Good Luck, Phil
Posted on Dec 30, 2008
  • 659 Answers
SOURCE: Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Posted on Apr 06, 2009
  • 5 Answers
SOURCE: Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
Posted on Aug 23, 2009
SOURCE: amtrol water heater WH-7P gets barely warm water
I had the same problem. I had a steam boiler and the water level in the glass gauge was below the top of the coil of the tank. remember water finds its own level, so it settled at the glass gauge level, therefore air got in coil.
to resolve problem : turned on manual water feed to boiler to raise water level. as water level got higher, let out water in hosecock between boiler and amtrol. amtrol noticed hot water reduction, circulator clicked on, boiler kicked on, turned off hosecock, turned off manual feed. I effectively bleed water out of line by running water out of amtrol as water feed in boiler increased water level above coil.
took a while to figure this out, so if this is the problem, dont feel to bad. keep water level of steam boiler high.
Posted on May 12, 2010
SOURCE: My Amtrol Therm-x-trol tank has
Sounds like the internal diaphragm has ruptured. The tank should be replaced immediately. You should disconnect the electrical power to the water heater and close off the incoming water supply to the heater. Open a HW faucet to relieve the pressure and remove the tank. Be careful cause you are going to get wet. Replace with a new tank.
Posted on Oct 01, 2010
Amtrol them-x trol drum is leaking from top egde.I like to know how ti fix
Once these start to leak, usually the best solution is to replace the tank. It is corroding and will only corrode more with time. You could try epoxy for a short term fix, something like liquid metal.
Apr 18, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My A.O. Smith 8 year old water heater drips water out of the expansion valve but only when it is heating water. The builder of my home mounted the Amtrol THERM-X-TROL ST-5 in the horizontal position and I...
It seems that you have this figured. In their literature all units are shown vertical, either inlet up or inlet down. Also, it appears that if the unit is full of water, (water logged) pressure will build up in the system. Temporarily, you could shut off water to the water heater, open some drains and use a pump to put some air back into the tank. This would at least get air into the upper half of the tank for a while until you can get set to make a repair.
Gary
Dec 14, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I am loosing water pressure in my shower so I checked pressure at my ST-12 Therm-X-Trol tank hoping it would be 40 but water comes out of the test point and if you tap the tank it feels like it is full of...
you are correct....the rubber bladder inside the tank has leaked by and filled the expansion tank. it will need to be replaced and you also may find boiler or water heater relief valves may blow off until its replaced
Oct 21, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I have an Amtrol WH7L and the control panel is making a buzzing sound? Other wise it is working fine.
In a while the control unit will fail
On the Amtrol units the control is their weakness.Once it starts to buss it will last somewhere between a couple of weeks and a year, but it WILL eventually fail.
And while Amtrol advertise a "Limited lifetime warranty" the "Limited " part includes not putting any warranty on that control unit.
Jan 27, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Short buzzing noise every few seconds from hotwater tank
it maybe that there is a small leak at the connection.try to remove the tank and put teflon tape on the connection.this may fix the problem.if this does not fix the problem,it may be possable that the amtrol has a pin hole in it.this may hve to be replaced.good luck with your project
Sep 29, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My water heater is buzzing then shutting off. (no hot water)
the power interrupt switch is detecting a short in one of the heating coils.  With the power off remove the side cover pull out the insulation and disconnect the wire to one of the heating elements.  Make sure it isn't touching anything and turn the power back on and see if the problem continues.  If it does reconnect the wire and do the same to the other heating element.  Be careful.  If you feel uncomfortable doing this call an electrician.
Mar 30, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
How do I change a amtrol thermal expansion take, Is it as easy to unscrew and put the new one after shutting of the water supply
Yes. After attaching the new one,check air preasure with a tire gage to match the recomandation that come with the tank.
Feb 23, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Pipes humming in house
Dec 30, 2008 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Water Heaters Logo
59 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
