Computers & Internet Logo
M
Margaret Neville Posted on Dec 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to get at hard drive on Gateway 504Gr. I cannot get the side off --- the 'screws' if that is what they are are inverted and too tiny to get any screwdriver in. this tiny things are hold
I have removed what I see as all removable screws which has allowed me to get the front panel off. This would be the cover that has the on/off button. underneath is see the cd drive projecting out, 3 wires that are unavailable to me as they are sticking out of a hole, and a projected area of usb plugs and headphone plugs. These 3 visible components are inaccessible to me as there are wee tiny 'screws' if that is what they are --- are holding the metal down. The 'screw' seems to be rounded with an indentation in the middle that goes way below the outside rounded part. I just want to destroy hard drive to trash the computer.
joecoolvette
Level 3:
  • Gateway Master 5,660 Answers
  • Posted on Dec 15, 2014
joecoolvette
Gateway Master
Level 3:
Answers
5660
Questions
0
Helped
2194506
Points
18014
Margaret,
As you face the front of the Gateway 504gr desktop computer, the Left side panel removes.
Looking at the BACK there are two Thumbscrews to remove.
These are located along the edge of the Side Panel itself;
One located near the Top, and one located near the Bottom.
The thumbscrews may just loosen, and not come out. (Each thumbscrew is supposed to be held on by a small circular clip)
Once they are loosened all the way pull back on the Side Panel using the indented fingergrip molded into the side panel.
Pull back, and then when the panel stops, ease the side panel out.
The Side Panel has 'hooks' made into it, that match up into corresponding slots in the metal computer case frame.
This is why the side panel only slides back so far, then is eased to the outside.
With the Side Panel removed you will note there is a metal frame around the Harddrive. (Harddrive Caddy is the name of the rectangular metal frame)
Remove the power cable to the harddrive, and the data cable.
Remove the one or two Philips head screws which fasten the harddrive to the harddrive caddy.
Slide the harddrive back and remove.
(WATCH your fingers! There are very sharp metal edges present!)
Have any additional questions concerning this please post back in a Comment.
Regards,
joecoolvette
  • Margaret Neville
    Margaret Neville Dec 16, 2014
    I got it! Thanks so much. I got the Hard drive out and hit it many times with a hammer - but unlike other video's and articles I've read, I did not hear anything break inside. I bent it quit a bit though with the hammer and was also able to remove the small green 'diagram' plate on the drive which go me more inside the drive. I think? it is now safe for me to dispose it.
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Dec 23, 2007
SOURCE: Problem removing the cover to replace a CD drive
Remove the two screws on that side of the case on the back and then pull back on the panel It should slide back and off, The screws should be there where you can get to them. If that don't work there may be a tab inside by the drive you can push the button and the hole drive cage will turn out on a hinge, I hope that you can get them out now.
Anonymous
  • 6 Answers
  • Posted on Apr 12, 2009
SOURCE: Presario SR1030NX Hard Drive Removal
reg cure stinks try eusing FREE
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Aug 23, 2009
SOURCE: I am unable to remove the hard drive to install a
My Pavilion a1357c has only one screw on the open slider panel side, excuse me it only has screws on one side. Your only venue is to loosen that bracket until you can get access to that screw. Good luck my friend,Dana
Anonymous
  • 19 Answers
  • Posted on Apr 01, 2010
SOURCE: cd drive stuck
You should be able to simply use a paper clip (unbent) and push it through the very small hole on the front of the CD tray.
This will manually open the cd tray.
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Aug 07, 2012
SOURCE: remove hard drive from tower case gateway 815 gm
http://support.gateway.com/s/PC/R/4190/4190nv.shtml
Looking at the rear of the computer;
A) Two thumbscrews to loosen, then remove the Left Side Panel.
B) Two Philips head screws to remove for Right Side Panel.
(Designation of left/right Side Panels are looking from the Front, of the computer)
Pop the Front Cover off. WATCH the wires so they do NOT get disconnected from the motherboard!
Slide the right Side Panel back about an Inch, then lift out, and off.
Click on - Gateway Computer User Guide - in blue.
Now remove the 1 or 2 Philips head screws on the right side, that hold the Harddrive into the harddrive bay.
For additional questions please post in a Comment.
Regards,
joecoolvette
How do i get the hard drive out?
Gateway GT5056 Desktop Hard Drive Caddy Bracket Holder Mount HDD 2JB35 005
Look at this picture. It should look like the bracket your drive is mounted in. You must remove this caddy to get at the other 2 screws. above where you removed the 2 screws from the side of the drive, there should be a screw that holds this bracket to the frame. You must remove this screw. ALso there may be a spring loaded clip that stops the bracket from sliding out, you must lift or press this before sliding bracket.
good luck
I turn on the Gateway and the words Gateway come on screen, then it goes black. The keyboard is on then off then comes on again, Screen remains black.
You have a problem with the operating system. It has crashed. You will need to reinstall the operating system in your computer. Before you do that you need to back up your file in your hard drive.To do that you need a 2nd computer get a hard-drive closure external take out the hard drive of your gateway. and plug it in to the external closure and plug it in the computer and explorer and move the files you need to the other computer. After that put the hard drive back into the gate
Your computer came with a recovery disc. Use that to reinstall your computer and software. That will help your problem. Update your computer to make sure it doesn't fail again.
Gateway 504GR starts running then the monitor read "power saving"
mine does the same thing, the first time it did it, i removed the dial-up modem that it came with, and it booted up just fine with no problems. now, after a year ago of this happening it decides to do it again this morning, so i'm kind of clueless now, considering that there's no modem in it, so i have no idea what could be causing the problem
My daughter has a Gateway Lap she dropped it and now it saids no Bootaboe Device insert boot disk.However she does not have a reboot disk
If you are inclined, try and find where the hard drive is, and pull the hard drive out and reinsert it in it's bay. The hard drive on my Gateway is located on the left side about midway. Its cover is help in place by 2 small screws. Remove the screws pull the cover and the hard drive will have a strap to help pull it out. Pull it out then plug it back in see if that helps.
23helpful
2answers
Gateway w650i Physically removing a hard drive my laptop help
I ran into this same problem on the exact model laptop. The solution is to remove the two screws that are in the laptop hard drive on the right... Those are obvious... The next step is to remove the two little white space fillers that are to the left of the laptop hard drive on the furthest side from where you removed the screws. That allowed the entire hard drive to now slide to the left toward where those place/space holders were. (don't lose those white pieces) Once you have the hard drive slide all the way left away from the connectors that were holding it in place you can slide up one side of the Hard Drive and easily pull it out!
What is the easiest way to remove hard drive from a Gateway T 6313??
I have a Gateway 7510GX. Turn the laptop over. On the side closest to you should be a cover that is held in place w/one or two screws. Reomve this cover and the hard drive should be underneath it. One screw is all that is holding the hard drive tray and the hard drive in place. Remove the screw and gently wiggle the tray loose. There are probably four screws holding the hard drive into the tray. Replacement is the opposite of removal.
Gateway will not turn on.
Sounds like the power supply. Here is the part number that you can shop for online.
Bestec ATX-300-12EB3 power supply. Rev. S2
I found them on Yahoo shopping for as low as $47.39.
Hope this helps.
Noisy-part 2
look at the rear of the pc. the motherboard will be on the side all the connectors are off centered. so if all the connections are on the left, open the right side. if the fingerscrews are off.... slide the side toward the rear of the PC and it will let go. There are little tabs holding it in place.
3answers
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
