Question about Haier Washing Machines
My Haier washing Machine vibrates and makes a very loud vibration noise.
Can you help me?
    Problem Solver:
  • 8 Answers
Have you noticed any grease or oil stains on clothes coming out of the washing machine?
In my personal experience, heavy vibration and loud noise during spin cycles has been caused by the bearing being broken and further damage caused by running on a broken bearing. If that is the case it is a costly repair, I had to get a new washing machine.
Washing machines are simple to take a part to a small extent, just remember in what order you took things off if you decide to investigate further your self.
Posted on Dec 15, 2014
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: machine making loud noise and vibrating strongly
its the brum bearings thats gone
Posted on Apr 21, 2009
  • 42 Answers
SOURCE: Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Posted on Jul 22, 2009
SOURCE: spining makes noise and machine vibrates a lot
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
Posted on Sep 01, 2009
My Fisher & Paykel 8.5kg Washing machine (WH8560J1) vibrates and makes a very loud noise during washing cycle. The vibrations is that bad the whole machine moves of its base. What is the problem?
Main Bearing worn, time for an overhaul! get it looked at sooner rather than later, as motor and shaft damage can occur. it's expensive, sorry to tell you, but cheaper than a new one!
Jul 18, 2017 | Fisher Washing Machines
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Machine making a loud noise in spin cycle. We
Inspect the outer drum to see if one of your springs has popped off. You can also inspect the lower drum area to see if your vibration dampener has worn out or broken free. Also you may need to check your rear bearing just between the large pulley and the drom to make sure is hasn't separated from it's mount.
Mar 02, 2010 | Frigidaire ATF6000ES Front Load Washer
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
hi,
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Vibrating only on final spin
no cement is perfectly level so you will need to level it with a spirit level
Jun 11, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Loud Vibration
Check the front water bucket handle.
Sep 10, 2008 | Haier Dehumidifiers
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Washing Machines Logo
201 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
