Question about Frigidaire Refrigerators
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air in the freezer around 0 F?
  • Frigidaire Master
  • 744 Answers
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Posted on Dec 15, 2014
  • geoff
    geoff Dec 23, 2014
    Thanks Richard. Very helpful
docjohn174
  • 943 Answers
SOURCE: freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Posted on Oct 17, 2008
  • 37 Answers
SOURCE: freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
Posted on Apr 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Posted on Aug 26, 2009
  • 1218 Answers
SOURCE: Food in refrig crispers freezes. Top of freezer too warm.
Good day,
You are right about it being little or no air circulation. There is a fan motor in the freezer, which you can access by removing the rear panel of the freezer panel.
That's the good news. The bad news it is a DC variable speed motor controlled thru a thermistor and powered from the motherboard located in the back wall of the refrigerator.
You can remove and take the motor to an appliance parts house that deals in GE parts. If they determine the motor is bad, then you could effect a repair.
If not the machine is too complex, and some parts so expensive that repair is best left to a GE qualified pro.
Posted on Nov 09, 2009
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
How to set AEG model 7522238-GA temperature
Normal for a freezer is around 0 Fahrenheit. 21 is barely cold enough, but ok, food will stay frozen. Freezing is 32 Fahrenheit, 0 Celcius.
Nov 29, 2013 | Kitchen Ranges
Frigidare PLHS67EGSB1 IS 6 YEARS OLD Temperatue Fluctuates On freezer side
Good Morning bernie3003 - For this particular model, the control on the door is the brain which controls all the functions of the unit. If the temperature inside the unit is not reading the correct temperature, then there might be a thermistor or wiring issue between the thermistor and the main control board on the door. I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts.
May 19, 2013 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Refrig is freezing foods and will not stay set at temp recom.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Psc25mstass freezer not cooling
I had a problem where the temperatures in both refrig and freezer wouls fluctuate. Would not geep ice cream frrozen in top of freezer but temp gauge would read 0. Even stranger would have stalagtites forming from the top shelves in the freeser (big ones). Still under extended warantee so tech replaced the mother board and iit is functioning well now.
Sep 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
May 18, 2009 | GE Refrigerators
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
154 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
