Question about Singer Sewing Machines
The zig zag stitch is on the bottom of the fabric instead of the top how do I fix this for a Singer sewing machine model 7015
    Problem Solver:
  • 8 Answers
In two words, this sounds like a problem with: thread tension. Quite possibly to the point of having an entirely mis-threaded machine, whether because the thread was not routed correctly, or because parts of the thread path are missing.
(Let's review - just for a sec - the basics of how the stitch is formed. The needle, carrying the upper thread in its eye, penetrates the material. When below the material, the needle begins traveling back upward, creating a loop in the thread. (Depending upon the type of machine, either a hook or a shuttle) then pulls this loop so that the lower/ bobbin thread runs then through it. Then, as the needle retracts further upward, an arm (between the tensioning disc/spring and the needle thread path) pulls upward of the thread, tightening the stitch into place.
If, for example, there is no tension at the tensioning disc/spring, that arm will take from the thread spool instead of tightening the stitch into place.
Posted on Dec 16, 2014
night71
  • 328 Answers
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
Posted on Nov 01, 2007
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
I dont have the instruction manual and i cant figure out how to do a zig zag stitch? Help
You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
Mar 03, 2015 | Sewing Machines
Singer Sewmate, the zig zag stitch is perfect on the bottom of the fabric, but lopsided on the top, how do I fix this?
This could be a combination of two things, to much down pressure on the spring loaded foot on top or the fabric distorting it, the other is a top stich tension issue adjust tension in and out to see if this improves the stich.
good luck
Feb 25, 2015 | Singer Sewing Machines
singer has a manual but you have to order it,, try adjusting the upper tension. and if that doesn't work then then bottom tension needs to be check, ,but don't touch the bottom tension unless it's really nessary
Dec 14, 2014 | Singer Sewing Machines
Can you post a pic of the top and bottom of a seam sewn on your machine? Also a pic of the settings.
singer has a manual that should show how to adjust the zig zag ,, but the manual is not free,, but it costs the less
Instruction Manuals
you may have to put your model number to get it
Raw edge zig zag stitch bunching underneath
When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
60 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
