My TV SET KEEPS BURNING FUSE
Put new fuse but wen I on it. burn again
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Dec 15, 2014
  • 275 Answers
SOURCE: fuse keeps blowing
Techman seems to have covered it up nicely. A fuse repeatedly blowing indicates a major short in the Circuits. Get professional help. If u are a techie, or a Semi techie, you could check the Rectifier diodes and the Power Supply regulator (STR).
Posted on Sep 07, 2006
  • 18 Answers
SOURCE: Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Posted on Aug 19, 2007
Slinteriors
  • 8617 Answers
SOURCE: t.v. keeps blowing a fuse
The storm probaly blew your horizontal output or one of the Diodes in the brdge rectifier. Hows your soldering skills and what model set do you have?
Posted on Jan 21, 2008
  • 135 Answers
SOURCE: fuse inside tv keeps blowing
Hi there!
If the fuse rating is correct as indicated on the board, then the PTC is probably busy going faulty. If not sure where it is located, normally on the front where the switch is and where the coil that sits around the tube is connected to the board. Little plastic box with three pins(sometimes two) black or cream in colour. Some circuits use a disc type with 2 legs, however not sure on your set. This is called the degausing circuit and demagnetises the tube every time you switch the TV on. Good luck, JUS004
Posted on Mar 16, 2008
  • 1525 Answers
SOURCE: My Tv was off during rain but there was thunder (lightning)
the fuse is doing its job when the fuse blow it stop the components being damaged. but in this case it sounds like component failer
Posted on Jan 18, 2009
Grinder does not work, keeps blowing fuses! Can I fix it?
You need to return it for repair or buy a new one.
Nov 24, 2015 | Saeco VIA Veneto Combi
My wiper fuse keeps burning out
If your wiper fuse keeps burning out, your wiper motor might be failing which causes too much amperes required to turn the motor which in turn trips the maximum rated amperes of the fuse.
Follow the wiring of that fuse to your wiper motor to make sure the wiring is not nicked and grounding to the metal. Once you confirm that there is no shorted wire, disconnect the wiper motors wiring connector. Fuse a new fuse and if the fuse does not blow anymore then you isolated the problem which is the wiper motor causing the fuse to blow. Fix or replace the wiper motor.
When diagnosing blown fuses, I usually temporarily replace any fuse in a vehicle with a circuit breaker type fuse. If there is still a short somewhere in the wiring or the component itself in line with the fuse, the circuit breaker fuse will just trip and I just reset it again after I fix the problem. An advantage of keeping to replace a blown fuse while diagnosing.
Oct 04, 2015 | Cars & Trucks
No power on zenith z36x31d
The fuse may have failed. However, since you mention smelling something burning, you'll need to check if other parts (for example: a resistor or diode) also was damaged. That burning smell suggests that you had a short in the circuit and high voltage got past the fuse. If you insist on fixing the TV, you will need to identify any short and fix that before attempting to use it again.
I hope this helps.
(I've dealt with several resistor fires over the years. Sometimes the resistor or Zener diode is actually the fuse for the circuit. That simplifies the solution.)
Jul 11, 2014 | Zenith Z36X31D TV
Car wont turn over. no clicking when I try to start it
I would first have to ask, what fuse keeps burning out. The owners manual will tell you what it is for. As for the fuse that keeps burning out, this is cause by a short in the system that this fuse feeds. Were the short is i can't help without knowing what the fuse feeds.
May 10, 2014 | 2002 Ford Explorer
My blower motor resistor burned up I'n my 05
Are you putting the right amp fuse in place of that fuse was at ? If you have a fuse that is 5 amps smaller could produce this same problem so go make sure your manual says what amp fuse goes there first. This might solve the issue. Usually if the fuse keeps breaking inside of it means that there might be a short some where else.
May 24, 2011 | 2005 GMC Sierra Denali
Fuel and engine temp gauge fuse keeps blowing, why?
the fuse basically protect the circuit from burning up...wen it blows the circuit is incomplete so it cant burn up...something is causing your circuit to burn up or use more electricity than the wires or circuit can take....in order to fix this problem you will need an electrical diagnostic
Jan 18, 2011 | 1997 Mercury Sable
Bowing fuses
you need to repair the power supply section of your tv.there is a shorted parts in there that's why it keeps on burning your fuse.
Jul 17, 2010 | JVC AV-36D503 36" TV
KEEPS BURNING FUSE FOR POWER WINDOWS/LOCKS ITS PINK SQUARE 30 AMP
check ur trunk where there is a cap thing back there where wires run to make sure that didnt burn i have 1998 camry that did the same as urs and i checked mine and i fixed mine and now everythings works now
May 27, 2009 | 1996 Toyota Camry
2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
May 10, 2009 | 2001 Ford Crown Victoria
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
