Question about Frigidaire Washing Machines
Model ftw3011kwo washing machine won't work after breaking locking lid piece
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
Posted on Dec 16, 2014
  • 51 Answers
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Posted on Jun 12, 2009
  • 251 Answers
SOURCE: washing machine won't go thru spin cycle. Lid
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Posted on Jul 15, 2011
trinhblue29t
SOURCE: the Maytag TL lid lock
Hi, I have a code-OD at washer Maytag FAV6800 . What this mean and how can solve? Thank You!
Posted on Mar 07, 2012
richroth
  • 9472 Answers
SOURCE: Samsung washing machine door won't lock
What is the model number?
Posted on May 21, 2012
richroth
  • 9472 Answers
SOURCE: The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Posted on Oct 21, 2012
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Frigidaire washer modle ftw3011kwo
Do you notice any beeping, flashing, or error codes? You could have a bad lid switch, door latch or even a timer. A professional would need to diagnose the unit if no error code is appearing.
Aug 02, 2012 | Washing Machines
Frigidaire Stackable model #FEX831CSO door won't open
Unplug the machine and where the lid is latched you can push a piece of wire wire in the same hole it latches through. The wire will bottom out after in the hole about a inch. Push it slightly farther and try raising lid as your pushing. All the lock is is a metal tab that pushes up and down. After time the enclosure it's attached to splits and makes it fail but it can be opened with whatever goes farther in that hole then the latch itself.
Jun 16, 2012 | Frigidaire FGX831CS Top Load Stacked...
Locking mechanism
replace the lid lock ! its a safety measure. I would not recommend removing or bypassing lid lock. just replace it. without the lid lock it will work with lid open. good-day ! if you really what to bypass the lid lock. Find the wire that goes to the switch. Splice the wires together and the machine will think the lid is shut all the time. if you can not get top of washer off. just call an appliance center and give them the model and serial number. and they should be able to tell you. good-day !
Dec 13, 2011 | Kenmore Washing Machines
The Maytag TL lid lock was not unlocking. finally after repeated unplug-plug, etc. it unlocked. I snipped off the plastic hook on the washer (not lid) & now it won't go into the wash cycle. ...
Google this for a similiar issue of breaking the Left Hand Lid Lock.
lid lock assembly look for forum response by dh1200s.
You are going to need a complete L.H. Lid lock assembly. p/n 25001048 Google for best price.
You have the issue of the Lid Locks no releasing so even after a replacemant L.H. Lid lock assembly (not cheap) you have the root cause issue to troubleshoot.
If you want to troubleshoot Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
It's free because my time is free. I post as dh1200s at that forum and others as well as here. FAV6800AWDIY is my second account on this forum......Good Luck
Aug 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
Washing machine won't go thru spin cycle. Lid lock light flashed some at first, now won't come on at all.
Jul 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
