SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
SOURCE: Brand new Bosch PS 20 drill
It's the nature of the beast. It should be snug enough not to fall out, though. Virtually all cordless screwdrivers have a bit of end play to them.
SOURCE: I can't change the bit on my Bosch PSB 650 RE drill
see if there's not secured to the shaft with a screw inside at the bottom of the bit. try to slack it by turnig it clockwise. then catch a 19 mm. open end spanner in a bench wise put the shaft with its two flat sides in the spanner and with a pump pliers catch the bit and unscrew the bit turning counterclockwise this time
SOURCE: A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
