Question about Refrigerators
How do I open the freezer compartment matsui refrigerator without breaking the door.It has only been opened once when I purchased it and was difficult to oshut and open so I chose not to use it. It&am
I'm afraid to use too much force as I might damage the door doing so.
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The door is probably frozen shut with ice. You may try to melt the ice around the gasket.
If the door has guide rails the only thing you can do is shut the unit down for 24 hours and hope that is enough time to melt the ice on the rails.
The problem with doors on rails is, if you do not close them flush, warm air can get in and ice everything up. They can get out of alignment and create a open gap.
Posted on Dec 15, 2014
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
SOURCE: Door difficult to open
Simple fix! A small puddle of water near the fridge led me (indirectly) to this fix. Our model is a fridge only, no ice or water dispenser and nothing spilled inside. Upon closer inspection I found a narrow tray along the back wall above the crisper drawers with a drain hose leading under the unit. Apparently it's a condensate drain, a plugged one at that! I cleaned it out, yuk, and soon discovered it serves a dual purpose... as a vent to help relieve the pressure from the vacuum created immediately after closing the door. It has renewed our love affair with this fridge. Hoo Hoo!
Posted on Dec 18, 2008
SOURCE: Maytag Plus side-by-side freezer constantly needing to be defrosted
Water is collecting on the bottom of the freezer and freezes then it becomes so much it starts to leak out side the freezer door. get about 1/4" thick. Is there a leak some where? Take about 2 days to form.
Posted on Jun 18, 2009
garing
  • 998 Answers
SOURCE: freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Posted on Aug 04, 2009
  • 34 Answers
SOURCE: My freezer door will not stay shut. Dometic Model RM2453.
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Posted on Jan 03, 2010
MY ICE MAKER MAKES ICE BUT FREEZES UP AND TRHEN I CAN'T GET ICE OUT. I TRIED TO OPEN UP THE FREEZER COMPARTMENT BUT I CAN'T GET THE COMPARTMENT DOOR OPEN. HOW DO I GET THE ICE MAKER DOOR OPEN. I...
Unplugged, Then allow 1 or up to 5 hour then open, if not get screw to open the compartment door. check all side of the compartment door. avoid so much full content to your ice maker refrigerator, and always give a free space to the compartment door.
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
The top compartment in the refrigerator is cooling effectively. But the lower compartment in the same refrigerator is not at all getting cool. Why is this so?
your damper vent door from the freezer to the refrigerator compartments is either stuck or frozen shut from moisture,sometimes they break and jam too,if this door doesnt open and close your food will get too warm or cold the door needs to move to keep the temperature correct
May 13, 2011 | Whirlpool ET1MHKXM Top Freezer...
Why is there no cool air going into my refrigerator when freezer door is shut but works when freezer door is open
Good day,
All cooling comes from the freezer compartment. There is a supply vent connecting the top of the freezer to supply some cold air from the freezer thru the opening on the top connecting the freezer compartment to the fridge side.
As well there is a second opening or return chute located in the fresh food section on the bottom lower half, that allows air to return the air back to the freezer, completing the air flow cycle.In almost all cases, the return chute going from the fresh food section to the freezer compartment has become blocked.
Usually iced up.
It will ned to be completely defrosted. Many times, the return chute is difficult to see and in many cases almost impossible to defrost easily.
If you can see the blockage, then it can be defrosted with the gentle use of a hair dryer.
However, if too difficult to access, you may need to open both doors and leave the machine unplugged for an extended period, usually 12 to 24 hours.
I know it's a pain, but sometimes necessary. Many times, rushing a refrigerator repair is impossible.
The reaon it works when you open the doors is, you have given the machine a secondary source of air from the room.
Jun 29, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
ICE GATHERS AROUND THE DOOR OF THE FREEZER COMPARTMENT
very possible the door seal is bad. Take a dollar bill and close it up in the door and see if has some resistance when you pull it out if not the seal needs replacing.
Jan 24, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer door closing problem
Aug 04, 2009 | Refrigerators
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Condensation in the refrigerator side by side GE Monogram
with the domestic door open hit the door switch and you shoud hear or feel the movement of air. i say you have no air circulation or a blocked condenser drain water is not getting back to the evaporator tray
Mar 28, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Jul 14, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
