Color of wire to pin letter for a miller 24a 14 pin connection
    Brigadier General:
  • 3,400 Answers
TO LITTLE INFORMATION.
Posted on Dec 15, 2014
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
Need pic of power hook up to mother board
How about the motherboard manual instead?
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800+SE&p=1&os=
To the right of the - Select OS - box, click on the blue Down Arrow.
Click on WinXP
(Doesn't matter which Operating System is chosen, we're just going after the motherboard manual)
Scroll down, click on the + sign to the left of Manual (10)
Scroll down, go to the 4th file down -
Version E1886
P4P800 SE User's Manual English Version E1886
Right underneath this file name click on the Blue - Global
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Global, it may take up to 30 seconds before the first page comes up.
At the Top of the Adobe Reader is the page number box. It is to the right of Page: and the Down Arrow.
You can go page by page to arrive at the page you want, or if you know the page you want; perform this,
1) Put your mouse cursor in the page number box, to the Right of 1
Left-click once. Now backspace the 1 out.
2) Type the page number you want.
3) Press the Enter key
Go to Page 25 - 2.2.3 Motherboard Layout
[Use the Zoom Out icon at top ( - ) by clicking on it, to decrease the view size.
Use the Zoom In icon ( + ) to increase the view size ]
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel connect to; is the Front Panel header.
Goes by many abbreviations.
Here we see it is PANEL_1
Two rows of 10 contact pins.
Now go to Page 55 - 12. System Panel Connector
I see no numbering system is used, so I will number the pins.
The Top row is numbered EVEN.
The Bottom row is numbered ODD.
Starting on the Top row, going from LEFT to RIGHT,
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
Starting on the Bottom row, going from Left to Right,
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pin 5 is N/C. Not Connected. Don't even know if the pin is there, or just a blank spot. (But you will)
C) Pins 7 and 9 are for a SMI lead.
"System Management Interrupt Lead (2 pin SMI)
The 2-pin connector permits switching to suspend mode, or "GREEN" mode, in which system activity is instantly decreased to save power and to expand the life of certain system components. Attach the case-mounted suspend switch to this 2-pin connector."
Suggest leave alone.
D) Pins 11 and 13 are for the Power On switch.
E) Pin 15 is N/C. (Or again, may not be there)
F) Pins 17 and 19 are for a Reset switch, IF a Reset switch is used.
G) Pins 2, 4, and 6 are for a Power On LED. (Light)
A 3-wire Power On LED.
Pin 2 is for a Positive ( + ) wire.
Pin 4 is for a Positive ( + ) wire
Pin 6 is for a Negative ( - ) wire.
This is for a Power On LED that is Dual Color.
Used back in the day when there was Turbo Mode, and Normal Mode.
A farce in reality.
Turbo Mode WAS the normal mode, while Normal Mode was a lesser version.
Usually a Green/Yellow dual color LED.
Green - Turbo, Yellow - Normal.
One side, or can be said as color; of the LED went to Pin 2.
The other side, or other color, went to Pin 4.
Ground (Negative - ) wire goes to Pin 6.
If using a Single color LED, (2-wire), suggest connect Positive ( + ) wire to Pin 2, and Negative ( - ) wire to Pin 6.
H) Pins 8, 10, and 12 are for Bambi to use, when running around without spots...
NO!..............you gonna' believe that, geez?
I just wanted to see if you were following along, after the dual color LED thing.
Pins 8, 10, and 12 are N/C.
I) Pins 14, 16, 18, and 20 are used for a small internal speaker.
Used to hear BIOS Beep Codes.
Pin 14 is for the Positive ( + ) wire
Pin 20 is for the Negative ( - ) wire.
Also uses a 20-pin ATX main power cable, (Right side of Ram Memory slots),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
,and a 4-pin ATX +12 Volt power cable, (Bottom left corner of processor socket),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P4P800 Motherboard
Mother board manual for Chiantech VNF4 Ultra
http://www.motherboards.org/mobot/motherboards_d/Chaintech/VNF4%2BUltra%2BZENITH%2BVE/
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Motherboard installed in computer case, (Processor to the Top, Ram Memory slots to the Right), the Front Panel header is at the Bottom/Right corner,
http://img.neoseeker.com/v_image.php?articleid=1773&image=24
Black rectangle of plastic with 17 contact pins. Top row has 9 pins, Bottom row has 8.
Notice that the Bottom row has a White triangle pointing to the first pin.
This triangle points to Number 1 pin.
Top row has 9 pins.
Starting on the LEFT side going across to the Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
Bottom row has 8 pins.
Pins 1, 3, 5, 7, 11, 13, NO PIN, and 17.
A) Pins 1 and 2 are for the Green Button. This is also the Standby button.
Let's discuss this for a moment............
Myself I wouldn't connect to it.
B) Pins 3 and 4 are for the HarDDrive activity LED.
(Light Emitting Diode, so to call it an LED light is redundant)
Pin 3 is for the Positive ( + ) wire.
C) Pins 6, 8, 10, and 12 are for an internal speaker. Used so the computer can generate BIOS Beep Codes.
Doesn't indicate which pin is for the Positive ( + ) wire, but with most motherboard speaker setups, Pin 6 would be for the Positive ( + ) wire, and Pin 12 for the Negative ( - ) wire.
D) Pins 5, 7, and 9 are for the Power On LED.
Notice there are 3 pins. This is used for a dual color Power On LED light.
Usually a Green/Yellow.
Pin 9 is for the Positive wire.
Two wire Power On LED? Positive wire goes to Pin 7, or Pin 9. I believe both to be a Positive connection.
Pin 5 I believe to be the Negative connection. ( - )
(I suggest connecting the Negative wire to Pin 5. Then connect the Positive wire to Pin 9. Not very bright? Put it over to Pin 7 )
E) Pins 11 and 13 are for the Power On switch.
F) Pins 14 and 16 are for a Reset switch, IF a Reset switch is used.
G) N/C for Pin 17. No Connection.
H) N/C for Pin 18. No Connection.
Here's the full review starting from Page 1 detailing the motherboard,
http://www.neoseeker.com/Articles/Hardware/Reviews/vnf4ultra/
Regards,
joecoolvette
Aug 27, 2012 | Chaintech VNF4/Ultra ZENITH VE Motherboard
I need a wiring diagram to install my Ultra Durable Motherboard model GA-Z68MX-UD2H-B3
This is Gigabyte Support, and the main support page for the Gigabyte GA-Z68MX-UD2H-B3 motherboard,
http://www.gigabyte.com/products/product-page.aspx?pid=3854#ov
On this page I invite you to click on the Downloads tab.
(Overview, Specifications, Downloads, News/Awards, etc)
To the right of the Download Type box, click on the blue down arrow.
Click on Manual.
You want the third file down,
English - 1001 - pdf - 28.91MB - 2011/05/02
Under the Download Here heading, click on the name of the country nearest yours.
This is a PDF file. It may take up to 30 seconds before you will see the first page.
It may also take additional time for the file to fully download.
(The computer you are using now has Adobe Reader on it, which uses PDF files)
[ I'm using Adobe Reader X (10), and a medium speed DSL connection. Took over 65 seconds to download, clicked on America. Longest PDF file download I have had in a long time ]
Page 7 shows a layout of the motherboard.
Processor to the Top, Ram Memory to the Right, the Front Panel header is to the bottom right corner.
{The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
F_PANEL }
Page 23
10) F_PANEL
Page 28 - Front Panel pinout
The Front Panel header is parallel to the bottom edge of the motherboard, and lays out horizontally.
Two rows of 10 pins. Total of 20 pins.
The Top row is numbered Evenly. Pins 2 through 20.
The Bottom row is numbered Odd. Pins 1 through 19.
A) Pins 6 and 8 are for the Power On switch.
(If there is a Positive { + } wire it goes to Pin 6)
B) Pins 10 and 12 are not shown. No Pins 10 and 12.
Pins 14, 16, 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
C) Pins 1 and 3 are for the HarDDrive activity LED light.
The red LED that blinks when the harddrive is actively in use.
(Pin 1 is for the Positive wire { + }
If the LED light is dim when operating, switch the wires )
D) Pins 5 and 7 are for the Reset switch, IF used.
(You can go through Task Manager, and do the same thing.
OR you can also simultaneously press the CTRL, ALT, and DELete keys)
E) Pins 9 and 11 are for a Chassis Intrusion switch.
If the computer cover is removed there is no power to the motherboard.
This is IF a chassis intrusion switch is connected to these two pins.
It may have the style that the switch is in the open position, allowing No electricity to pass through to the motherboard, when the computer cover is removed.
Or it may have the style where the switch closes, and connects to Ground, when the computer cover is removed. Again no electricity is allowed to pass through to the motherboard.
Test to see which way works. Jumper wire across these two pins.
Default setting is probably nothing connected to these two pins.
F) No Pin 13
G) Pins 15, 17, and 19 are for the Power On LED light.
There are three pins for using a dual color LED light.
Pins 15 and 17 are for the Positive wires.
One pin goes to one color (Side) of the LED light, the other pin is connected to the other color (Side) of the LED light.
Pin 19 is for the Ground { - } wire.
Dual color LED lights were used if a computer had 'Turbo' mode. The computer was supposed to operate faster in Turbo mode.
In reality the computer operated at normal speed in Turbo mode, and lesser speed in the normal mode.
If your Power On LED light is a single color LED, connect the Positive { + } wire to Pin 15, and the Negative { - } wire to Pin 19.
As for the wires coming from the Front Panel, you'll have to trace them down to see what is what.
Power On switch wires, Power On LED wires, etc.
Regards,
joecoolvette
Jul 24, 2011 | Computers & Internet
Need to know on the 14 pin connector what color wire goes to what pin on a miller s-22p12 remote
I would go to www.millerwelds.com and download the owners manual based on your serial number. It will insure you get the correct wiring diagram for your feeder.
Aug 21, 2009 | Miller Welding Tools
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
