Question about Jenn-Air Kitchen Ranges
My Jenn-air JDS8860BDP keeps shutting off during oven pre-heat and both convection bake and regular bake. I had a repair guy come out and he said the control board and sensor would need to be replaced
The only information the repair guy left with me after looking at the stove was that it needed a new "main board" for $288 and a "sensor" for $72. I would like to order the parts myself but need to know if there is more than one "main board" part for this stove. I'm getting varying prices when i look online.
    Top Expert:
  • Jenn-Air Master
  • 46,437 Answers
As a former repair person, unless you had said please fix it , you would have gotten no information .SORRY but fixing is how we survive .
Posted on Oct 04, 2015
Amigaman
  • 248 Answers
SOURCE: jenn-aire gas stove
  If this is a gas range your problem is most likely your oven ignitor.  As they get older they get weak and takes longer to open gas valve.  Eventually it won't come on at all.  Replacing the oven ignitor will often take care of problem.  BE SURE TO UNPLUG UNIT BEFORE REPAIR!!
  Remove oven floor.  The ignitor is in a cage attached to back of oven burner.  It mounts with 2 screws.  You may have to cut wires and wirenut in replacement.  Doesn't matter if the 2 wires are reversed.
Posted on Oct 24, 2007
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
watugot
  • 290 Answers
SOURCE: Kenmore Electric Stove - Gourmet Edition
Thanks for the numbers.
The 628 in the model# tells us it was built by Frigidaire. The date code in the serial number is less clear because it is a different code than their current serial number designations that have been in use since the mid '80's. The style of the stove makes me think late '70's, I would guess '77 or '78 from the first 3 digits of the serial number.
The thermostat should be easy to check. If the broil function in the large oven works, the thermostat should be ok. It is a simple switch that should read closed across the contacts when you turn it to any temp setting when the oven is cool.
The power for the oven will also go through the selector switch which routes the power to different components depending on the setting.
The power also goes through switches in the clock that allow the timed bake and self clean functions to work.
If there is no wiring diagram in the stove, you will probably need one to diagnose the problem if the thermostat checks ok. I would suggest getting one while it is still available in case you need it in the future.
Once you have found out exactly which part you need, you should be able to use the Frigidaire part number from the parts list on the Sears site to track down a replacement part through a local appliance parts dealer. You may have to take the part to them to try to visually match up a replacement. Thermostats and selector switches are usually pretty generic in their operation between manufacturers, the problem lies in finding one that will mount to your control panel properly and that your knob will fit so that you can keep the same uniform look along your control panel.
Please post back with what you find out or if you have any questions.
Thanks/Mike
Posted on Mar 04, 2008
aborcass
  • 2651 Answers
SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Posted on Nov 24, 2008
SOURCE: Jenn Air range model SVE47600 Beeping
range was beeping and showing code f4....would not stop unless i turned breaker off
Posted on Nov 12, 2009
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. Catriver...post back.
Feb 24, 2007 | Jenn-Air JGS8850BDS Stainless steel Gas...
Kitchen Ranges Logo
184 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
