Question about Sportcraft Exercise & Fitness
How can I geta manual for a Sportcraft treadmill Model #04050?
I tried Sportcraft,LTD on the internet but they are out of business.
    Habit-Forming:
    Scholar:
  • 51 Answers
Gackmaster
  • 12 Answers
SOURCE: i have a sportcraft tx 2.5 treadmill thats needs
Can you give more details? are you saying it stops 7 seconds after you step on it, (every time)?
If so, have you had the treadmill a while? this is an indicator of a worn belt. the belt is not sliding like it should, and drawing too much current. your control board will 'clip' the current off after a pre-set time, to avoid burning up components.
other things it could be:
1. your belt is too tight. did you tighten it lately? When did your treadmill start doing this?
2. The motor is going bad, and drawing too much current.
3. motor control board is bad.
look at your motor's current rating: measure the current draw when you get on it. if the current draw is ~ 80% of the rated current of the motor, and your belt is good,..and not too tight, it could be the motor.
if the treadmill is stopping while only drawing 4 or 5 amps, I would lean towards the control board is bad.
cheapest way to get started troubleshooting. Ensure the belt is not too tight, (adjust to only about 3 inches slack, when you pull up on it). next. buy some belt lubricant and lube it up.
If this doesn't fix your problem, keep looking for other fixya help. someone with SportCraft TX 2.5 specific experience. Sorry, I only have generic help here.
good luck.
Posted on Jan 27, 2010
SOURCE: Can I fix my Sportcraft TX400 Treadmill ?
adjusting the belt
Posted on Jun 19, 2010
  • 218 Answers
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
SOURCE: e5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Posted on Mar 15, 2012
I need a owners manual for Sportcraft TX 7.0 treadmill
Google (sportcraft)(TX 7.0)(manual) without parens.
Jun 06, 2018 | Sportcraft Exercise & Fitness
Need owner's manual for sportcraft TX 5.0 treadmill
Try Google with model number make serial number ,they may be able to help.
Jul 20, 2014 | Exercise & Fitness
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
A backwards E appears on my treadmill model 3-1-04-050 FH what does this mean?
Read your instruction manual, section troubleshooting for indication.
However you must adjut THE reed switch, see the diagram attached, clean, and tigh the connector wires very well. God bless you.
Run the software calibration for diagnose, and troubleshooting too.
Jun 07, 2012 | Sportcraft Tx 455 Sportscraft Treadmill...
Location of speed sensor on sportcraft tx 400 treadmills
It is a simple magnet and Hall effect transistor if you have 2 small wires. It usually attaches to the 1/8 inch mini plug. You can test it with an analog meter, the resistance will be stable at rest, and with treadmill in motion, the resistance will change as the magnet passes the hall effect switch. moving the track at slow speed manually will be enough to see the needle move. Speed is calculated off of the rate of those pulses.
Jan 23, 2012 | Sportcraft Exercise & Fitness
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Feb 25, 2010 | Exercise & Fitness
Exercise & Fitness Logo
432 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
