Question about Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
Rethreaded
  • Sewing Machines Master
  • 1,860 Answers
Try changing the needle
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
Posted on Dec 15, 2014
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
My machine is jamming, the bottom threading gets way too loose. and jams the machine up. I dont have an manuel or any instructions.
Ironically, often times when the bobbin thread is knotting up, it's the top thread that needs the adjustment. Loos top thread thesion will tangle up in the bobbin cassing...Think about it for a minuted. Try a quarter turn to the right on your top tension and then go fro there. There could be a problem with the bobbon casing tension adjust screw and plate. but I doubt it...Nine times out of ten when the bobbon thread is tangles the top thread is too loose.
Sep 01, 2011 | Singer 3116 Simple
I have put the bobbin in my machine, pulled it up with the top thread satisfactorily, and when I attempt to sew the bobbin thread gets all tangled.
You top threading is not right, totally unthread your machine, insert a new needle (flat side facing away), now rethread paying close attention that your thread is not tangled and is in each guide. Make sure that your presser foot is up when rethreading, very important. Now pull the top thread and see if it runs smoothly, then lower the presser foot, pull thread again, it should barely move. This seats your thread in the tension discs. Good luck
Mar 30, 2011 | Singer Sewing Machines
Thread keeps getting stuck in bobbin holder area
Unthread your machine, clean out the bobbin area and brush it, then totally rethread your machine. Make sure that there are no tangles in your thread. Try that, good luck
Sep 20, 2010 | Janome Memory Craft 4900QC Mechanical...
I have a singer touch and sew and the bobbin keeps knotting up when i sew. what could be the problem/
You may have tangled thread or the bobbin not threaded right. Totally rethread your machine according to your manual. If, you do not have your manual handy, download one for free at singerco.com. Good luck
Sep 12, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
My left thread keeps breaking! Its getting snipped by the needle above it. How do I fix this? I've been working on it for 2 hours and read the instructions very carefully, word for word :(
Is this a serger or a sewing machine? :Your needle may have a burr, so change the needle and insert the correct way. Also, check your threading, sometimes your thread gets tangled, rethread.
Aug 31, 2010 | Sewing Machines
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Sewing Machines Logo
    95 people viewed this question
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Chris Wetmore
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
