Question about Video Game Consoles & Games
How should I fix error code 205964 on my wii?
Wii u error code 108-0170
This is the "official" nintendo explanation:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=108-0170&system=Wiiu&locale=lang
If those items do not work, I highly suggest in it being that new you request service, replacement etc. under warranty by calling their # at the bottom of that page.
Dec 22, 2012 | Nintendo Wii U
Wii disc error
If you have the wii disc error that might be because of error code 32004. It could be possibly error code 32004. If you have internet on the Wii and if so if you Wii format it again then you'll see this problem because the Wii update asks you to update it. In the update message it said at least,"Not updating this could cause future game disk problems when playing games." Im not sure how to really fix it but this just the problem. Solution has to do with you either hacking the wii or certain cases. Buy a new Wii or see if you can fix it using Nintendos support.
Dec 02, 2012 | Nintendo Wii Console
Error code 52230 Can not connect up on wii to
This error is an issue with your router's firewall. You can find Nintendo's help on this error here:
http://www.wiierrorcodes.com/wii-error-52230-52232.php
One of the best ways to fix this would be to set up a static IP address on your Wii that is outside of the DHCP range of the router and then open up your router settings and configure a DMZ to point to that IP address. This will place your Wii completely outside of the firewall.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 09, 2011 | Nintendo Wii Console
I keep getting an error code on my wii can you please tell me what it means 51030
Not only will I tell you what it means, Kyle(can I call you Kyle? Good), but I will offer a solution to this problem AND give you something that will help you out with any future Wii errors. Brace for HELPFUL.
Error code 51030 means that you're unable to connect to your wireless network. Woah woah woah! Easy there Kyle, don't throw out your Wii just yet; wii can fix it! (I do puns too)
Check out your router. Is it on? It should be. Now turn it off. Is it plugged in? Unplug it. Now do a little dance. Finished? Great. Plug it back in.turn it back on. Fire up the Wii and give it another go.
Still no good? That's no good! Let's try messing with some settings on the Wii. I know I know, settings are scary. Everything should just be automatic these days. Well don't worry, I'm going to walk you through it.
Turn the Wii on and at the main screen (the one with the channels) point to the bottom left. With your wiimote, I mean. C'mon Kyle, that'd be awkward if you were just pointing at your screen. Anyways, click it, then navigate to Wii Settings > Internet (it's on page 2). Click on a new connection, or delete an old one and then click on it. Go through and re-set-up your connection.
Everything should be awesome now. But if you recall, I said I'd help out with FUTURE Wii error codes as well. Am I magic, you ask? Yes, but that's irrelephant (not pertaining to elephants) and irrelevant.
So now, Kyle, I bequeath upon you this link. Use it wisely.
Notice on the left side there's a little box labelled "Error Code Lookup"? I think you can figure out what goes there.
It's.... it's the error codes, just so ya know.
RECAP TIME:
-Error Code 51030: Unable to connect to your wireless network
-To fix it, unplug and replug in your router. If problems persist, set-up a new wireless connection on the Wii. (Guide for that here)
-Future Error Codes can be check out here (box labelled "Error Code Lookup" on the left side)
I feel like we've learned so much today. The moral of the story? Anything is possible through teamwork.
Hope everything works out!
Mar 23, 2011 | Nintendo Wii Console
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
Feb 28, 2011 | Nintendo Wii Console
Cant get online through sky broadband
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP/WPA (one or the other not both)key matches the WEP/WPA Key you entered in the Wii.
If you double checked the WEP/WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11.
Jul 24, 2010 | Nintendo Wii Console
How to fix wii error 003
Error Code: 003 Please contact Consumer Service at 1-800-255-3700 for assistance.
Apr 09, 2010 | Nintendo Wii Console
Wii won't connect to Internet. Error code is 051330
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 25, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
108 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
