Question about Kohler Electrical Supplies
My kohler 12 RESM1 has no power on switch, run or auto, no LED, has new battery. How do I fix it?
New battery, replaced fuses, new 20 amp fuse has no power on it.
BEERbrooklyn
  • 101 Answers
SOURCE: Basslink
make sure ur ground cabke is as large if not larger then ur poweer cable.
Posted on Jan 23, 2008
SOURCE: car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Posted on Nov 18, 2008
michigan man
  • 3533 Answers
SOURCE: Auto trans shifting problem
check the sensor on the transmission and give these guys a call at Schram auto and truck parts 1-800-292-1032 they sell only GM parts or try online at www.schramauto.com
Posted on May 03, 2009
libaredneck
  • 119 Answers
SOURCE: fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
Posted on May 05, 2009
  • 246 Answers
SOURCE: My 17.5 Kohler engine runs for about ten minutes
Hello wesleyhann:
This Sounds like a Stator/Charging Coil or Voltage Regulator Problem.
>>Go to this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=bkP1h4rj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjksMjkmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1DaGVja2luZyB0aGUgQ2hhcmdpbmcgU3lzdGVt&p_li=&p_topview=1 and Use the Information and the Test Chart Links to Properly Determine the Charging System on your Engine and Correctly Test the Charging Sytem to Determine if it is Charging Correctly. These Charts and the Testing can be Used for Almost All Small Engine Charging Systems (Kohler, Tecumseh, Honda, ect). This Site Addy; http://www4.briggsandstratton.com/miscpdfs/RNT/alternator_id.pdf will Assist you in Determining you Charging System on this Engine.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
Kohler CH640-3075 (one year old and in a Grasshopper 720K) will not turn over. Battery charged.
check fuses first. then check starter solenoid for proper power and then this will lead you to either a safety switch issue or a power issue...
turn key on, pull pto switch... does pto engage, then your problem is at or after the key switch
Oct 08, 2013 | Kohler Engines New 20 HP Kohler Engine...
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
I need a power wire that is only live when the engine is running
Hi Warren,
What you're looking for is a "switched power source". This would be much easier if you provided the car's year, make & model. Regardless, here are the generic steps you need to follow:
Older cars have a terminal in the "fuse block" that was labeled "accessory" or "ignition". This terminal provided power only when the the key was turned to "accessory" or the "run" (or sometimes called "on") position. Some cars have more than one fuse block, many times this additional fuse block can be found under the hood or under a seat in the cabin.
You should probe the fuses with a DC volt meter one by one with the engine off and the key removed to see which ones have no power, then check those same "dead" fuses with the engine running. Once located, you should be able to use any of those fuses to power a low power device when the engine is running / key on accessory. Make sure that the power provided is 12 - 14 volts though - some newer circuitry is in the 8 volt range and will not work as expected.
Some newer cars however, make use of electronics that that turn power on and off independent of the key. Some will allow the radio to play, power windows to work, etc. after the engine has been shut off and key is removed for a predetermined length of time (10 minutes or so) or until the door is opened - whichever happens first. You may need to find the power lead for the radio, power window, or other device that works as described here and connect to it for a switched power source.
If you blow the fuse after connecting the new device, you'll need to install a small, inexpensive relay to control the new load. These are available at auto parts stores for less than $20. Instead of powering the new device, you would power the relay coil. Run a wire capable of handling the load (or greater) between the battery and one side of the normally open ("N.O.")switch contact on the relay, and the power lead of the new device to the other side of the normally open switch contact. The result will be that whenever there is power available to the radio (engine running / key on accessory), the relay will be energized. The energized relay will close the N.O. contact and bring power from the battery to the device.
If you oversize the wire from the battery to the relay, you can supply power to other devices such as radar detectors, GPS units, FM transmitters, power inverters for 120 volt devices, etc. Make sure the wire from the battery is fused properly and that the relay contacts are rated equal to / or greater than the amp rating of the this fuse.
I hope this was helpful & good luck!
Sep 08, 2012 | Cars & Trucks
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
My Kohler 11RMY (40 amp) standby generator will not start
You should have two wire remote Start/Stop. It may need to be shortened in order to start.
Jun 06, 2010 | Kohler 12 kW Emergency Power System -...
I was sitting at my computer, with my space heater running, and suddenly both of them went out. Assuming that I had drawn too much power, I went to the fuse box to flip the switch back. Much to my...
The service to your basement needs to be upgraded if you are going to run the heater and other electrical units. I would guess that you have a 15 amp line and need to upgrade it up to at least a 20 amp and with a 12 gauge grounded line. In the short term you may be able to get by using a heater that draws fewer amps.
This definitely sounds like your need to consult an electrician.
Feb 21, 2010 | Kitchen Appliances - Others
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Power locks do not work- where are the fuses inside the the van
The problem is the BCM. The fix is a software update. Resetting the computer by removing and then replacing the 20 amp fuse marked 10D in the fuse box under the hood next to the battery is a temporary fix.
Mar 23, 2009 | 2005 Dodge Caravan
Car amp blows 12 volt wire fuse
Jul 26, 2008 | Car Audio & Video
Electrical Supplies Logo
35 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
