Question about Sewing Machines
The thread is bunching up in the bobbin area and not sure how to fix it thought it was tension but noy have a My Style 100 2 years old
) have taken off feed plate and cleaned the area
    New Friend:
  • 38 Answers
Try a new bobbin
Sometimes the thread can get tangled in the bobbin
Also ensure all areas in contact with thread are clean and keep machine oiled
Posted on Dec 15, 2014
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
Bobbin thread bunching up on bottom side od material while sewinginto a mess, while top thread fine. HOW DO I fix this, please.
Hi, this is a lack of lower tension. Check to make sure your bobbin is seated correctly and that you have used the correct thread path. Check the tension by drawing some thread from the bobbin with your hand, if it reels off too easily, the tension hook for the bobbin is too loose, tighten it down a tiny bit with a small screw driver and try again. If the bobbin tension is normal, than the problem may be your upper tension, if it is too tight it can cause your bobbin to snarl. If a tension adjustment does not fix the problem, you may need to seek a specialist.
Oct 06, 2015 | Singer Sewing Machines
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
I have a Bernina 1008. The thread is bunching up underneath when sewing. I've cleaned and oiled the bobbin area, rethreaded and adujusted the upper tensnion- the topstitch looks fine, it's lumpy on the...
Hello. Make sure the bobbin is not backward. It seems the upper tension is still not adjusted right. If the bobbin pulls smooth focus on the top tension. Good Luck
Feb 13, 2014 | Bernina 1008
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Thread getting knotted
My machine does the same thing. Unplug the machine, and open the bobbin case. I would bet that you have "orphan" thread still sitting in the bobbin area that is bunching up the new thread.
Your bobbin area should be opened, cleaned and well oiled to ensure that no loose threads are sitting in there waiting to create "tension" with you and your machine.
I have found that when I have not cleaned out the bobbin area, there are loose threads, lint and fibers left behind from other projects that I have been working on.
Get a new can of compressed air, and blow out the lint, and left behind stuff, and see if that doesn't fix your problem. If it's been a while since you have taken it in for a "tune up", it should be done if you use your machine often. Happy Sewing!
Feb 05, 2009 | Necchi 3537 Mechanical Sewing Machine
Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Aug 24, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
