Question about Panasonic NN-H765BF 1250 Watt Microwave Oven w/ 1.6 cu ft Capacity, Popcorn Function, One-Touch Genius Sensor Cook and Reheat, 10 Power Levels & Child Safety Lock
Something in the door is causing microwave to shutoff. Sensor is on, but then shuts down unless,also you hold a certain pushing in the button.
  • 20 Answers
Adjust the latch switch assembly to make sure that the door hooks engage with the switches. Loosen the 2 phillip screws holding the assembly and slide back and forth to adt. Retighten when the door hooks are making solid contact with the switches.
Posted on Jan 19, 2015
Some sensor/switch is out?
There are two switches there do you know how to get into the control panel?? If not let me know I will walk you thru it
Jan 24, 2008 | Frigidaire PLMB209DC Microwave Oven
Can this be fixed by me?
Could be a bad door switch or a bad relay. With the door closed try gently pushing it up and down if at some point the unit fires up, one of the door switches is not making contact. As for the relays they are on the circuit board, but not replaceable unless you are very good at De-soldering. Also keep in mind microwave units have very high very deadly voltages stored in the capacitors 4000V that can easily kill so don't mess with them unless you know what you are doing!
Jan 06, 2015 | Daewoo KOR-630A Microwave Oven
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
GE spacesaver jvm240av microwave shuts down during cycle
I have not gotten a solution for this problem. I thought your website said one of the experts would respond for free. Seems like that must have been a hoax to give you the opportunity to sell me something. Shame on you!
I am still waiting for the free assistance, as advertised.
Dave
Nov 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
Oven will not work unless I push on the door
It's probably a broken tab on the dooir switch mount or a screw holding the door switch mounts is loose.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can also order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Sharp R-1480 Microwave Oven
GE Spacesaver XL1800
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It may also be a broken mount that holds the door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-H765BF 1250 Watt Microwave Oven w/ 1.6 cu ft Capacity, Popcorn Function, One-Touch Genius Sensor Cook and Reheat, 10 Power Levels & Child Safety Lock Logo
116 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
