Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Maytag model MEDC400VW0 continues to run after drying cycle is completed
Machine keeps running when using left hand drying cycle but shuts off when using right hand cycle.
    New Friend:
  • 38 Answers
Sometimes these machines have a cool down cycle which for most people is too long
Posted on Dec 15, 2014
Can someone help on a Maytag Neptune dryer MDG6800aw not heating up?I've changed the ignitor and it runs but after around 10-15 minutes I hear a grind like a stuck switch and the dryer is not heating up....
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 07, 2015 | Maytag Dryers
Maytag dryer stops after few minutes
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Feb 21, 2015 | Maytag Dryers
Dryer is only 4 years old, was drying perfect one load, then the next its not drying. Takes 3-4 times to get load completely dry.
Feb 16, 2015 | Dryers
My Maytag bravo Dryer is not drying my clothes correctly. The timer on the dryer keeps going up higher indicting it needs more time to dry?
Oct 13, 2014 | Dryers
My maytag centennial electric dryer will not heat the model # is medc499vwo I need know if u have a video that shows me how and also if its the heating element or what?
Oct 04, 2014 | Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Were there recalls on any of ghese models
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Apr 19, 2014 | Maytag Neptune Washing Machines
How do you unblock the print nozle
Remove the print head and put it under hot running water for about 5 minutes. Try and keep water away from the electrical contacts, but don't worry too much. Dry it with kitchen towel until you see no ink. If the ink is still coming strongly, continue washing. Dry again and insert into the machine and run the Nozzle test. If it is still faulty, soak overnight in isopropyl alcohol or vodka. Rinse, dry and try again. Still nothing, treat yourself to a new printer, and use it at least once a week to keep the nozzles clean.
Jul 29, 2017 | Epson Stylus Photo RX700 All-In-One InkJet...
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
161 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
